towing question
Old Feb 14, 2010 | 11:01 AM
85 FF / medic's Avatar
towing question
Im going to start towing my 4runner to the far away trail with my Titan crew cab. Im on a pretty low budget. Have any of you guys flat towed your truck w/ a tow bar before? how did it go? Should i just keep saving for a hauler?
Old Feb 14, 2010 | 08:53 PM
Windsor's Avatar
I think you'd be ok, so long as the tow bar is properly fitted to the 4runner (frame).
Don't flat-tow it with the transfer case in Neutral, the transfer case takes its lubrication from the input side (like automatic transmissions do).
On that note, if you have an automatic transmission, you must disconnect the rear driveshaft to tow. Just remove the entire driveshaft and toss it in the back of the 4runner.
Probably not a bad idea with a manual transmission, but my FOM (factory owner's manual) says this is acceptable for towing (manual trans in Neutral, xfer in 2H, driveshaft attached).
Old Feb 15, 2010 | 06:32 AM
Nice.... Any sugestions on where to buy a good towbar set up
Old Feb 15, 2010 | 07:41 AM
lokirx7's Avatar
U-Haul Most big name Towing/Rental places will have one you can buy. I believe Wal-Mart also sells a name brand tow bar as well.
Old Feb 21, 2010 | 05:28 PM
maco35's Avatar
I got one at harbor freight for 39.00 on special + 20.00 for safety chains.
4x4-runner
Apr 18, 2017 09:08 PM
4x4-runner
Aug 3, 2015 07:14 PM
TJWilly
Jul 31, 2015 02:05 PM
defrag4
Jul 31, 2015 10:50 AM
vanion2
Jul 29, 2015 06:17 PM
