Front anti wrap link
Old Nov 24, 2009 | 12:20 PM
flatyota's Avatar
Alrighty after looking at some of the builds on the site I have noticed that some of you do not have this installed on the axle anymore. Do I really need it?
Old Nov 24, 2009 | 12:25 PM
dropzone's Avatar
Fossilized
None of my SA toyotas over the years have had it. Some guys have bad death wobble with out it...
I think Roger aka 4crawler has something on his website about it here:
http://www.4crawler.com/4x4/CheapTricks/index.shtml
or try the google for toyota websites in my sig...it hits over 80 toyota websites for info
Old Nov 24, 2009 | 01:04 PM
muddpigg's Avatar
You'll have to change the push pull steering to high steer.
Old Nov 24, 2009 | 01:48 PM
4Crawler's Avatar
The torque rod is typically required for stock steering, as it keeps the axle from rolling forward under hard braking and preventing the resultant jerk in the steering. Also helps to protect the somewhat fragile steering j-arm as it is in parallel with the draglink. As noted, if you switch to crossover steering, it gets tossed in the dumpster as it is no longer needed for either function.
Old Nov 24, 2009 | 02:36 PM
Etype R's Avatar
I had to install one on my truck when it still had the stock steering. The previous owner removed it after lifting the truck. I got one made for a 3" lift from a friend, really helped under braking. I gave it back to him after doing the cross over steering.
Old Nov 24, 2009 | 03:21 PM
desertcamper67's Avatar
I used to use one with a drop and a heim joint on one end.
On this truck, I bent the bracket on the housing so I took the bar off. Its been off since 2005.
Old Nov 25, 2009 | 11:18 AM
flatyota's Avatar
ah makes sense ya I still have the good ol push and pul for now so I will leave it on until I got cross over. Also does that free up any articulation?
Old Nov 25, 2009 | 12:59 PM
89silverpu's Avatar
Yes, taking that torque arm or whatever its called off, and getting longer shocks will increase travel greatly! My buddy took the torque rod arm off and shocks off and I think his droop increased like 6 inches...then again it's not his daily driver he just uses it for fun
Old Nov 25, 2009 | 04:28 PM
Etype R's Avatar
I would not want to drive without it using the stock steering, the brake steer was not something I enjoyed.
Old Nov 25, 2009 | 04:56 PM
xjdubber's Avatar
Are these the same as on YJ's where they run paralell with the the steering? what about running it inline with the frame?
Old Nov 26, 2009 | 07:46 AM
flatyota's Avatar
The reason they dont run it inine with the axle, is because they didnt design it to stop axle and body trak but to stop the front axle from wrapping when you are steering. The steering setup that comes factory on these trucks uses a push and pull movement while doing this it is actually trying to wrap the axle back and forth, and it is exagerated when you brake causing brake steer.
Old Nov 26, 2009 | 04:04 PM
xjdubber's Avatar
Gotcha!
Never heard of somebody calling that axle wrap.
Old Dec 1, 2009 | 10:35 AM
You don't even need this to run parallel with the steering unless you are going with a coil sprung and linked front suspension. Not necessary with leaf springs although some old jeeps used them with leaf springs.
Old Dec 1, 2009 | 02:19 PM
flatyota's Avatar
Ya I have seen newer f450s running them as well i guess its to stiffen them up.
1994toyota
Jul 17, 2015 03:03 AM
Jonny246
Jul 12, 2015 04:51 AM
