altimeter and inclinometer troubles...:(
Old Jan 14, 2010 | 05:23 PM
Van Cour's Avatar
Exclamation altimeter and inclinometer troubles...:(
alright here it is.... i obught a altimeter/inclinometer gauge... told it worked accept a green light was out. the tilt is fin and incline reads great. so i tore apart the dash and looked for that plug that apparently you unplug from the heater control. well i plugged it in (i had new blue 194's in it) hit the light button and nothing. and yes i did spuin the bulbs around and put them in the other way. i had the key turned to... the heater control never lit up anyways but i though it was a bulb.i found another plug in near the glove box which i assume is for the glove box light and it plugged right in. that didnt work either. the clock plug in works with the clock though. what could be the prob.
yes the dash was apart before me since its a dif cab and i saw that my dash which i thought was factory gray was actually painted when i took it apart. im buying a true new gray dash but i would like to figure out why this altimeter plug in wont work..? idea's? could i just run a ground and power wire from battery? also anyone interested in a sr5 dash cluster got a spare.
Old Jan 14, 2010 | 05:25 PM
Van Cour's Avatar
also the heater control plug in wont even reach high enough to where i would have to mount the altimeter which would be the factory spot.... so disappointed definitly looking for help...
Old Jan 14, 2010 | 05:35 PM
grant526's Avatar
Did you have the Inclinometer grounded?
I have an inclinometer ready to install, but haven't taken the time to install it. I'm not looking forward to tearing the dash apart.
Good luck!
Old Jan 14, 2010 | 06:07 PM
Van Cour's Avatar
doesnt it ground itself when pluged in or do the bolts when mounting ground it?
Old Jan 15, 2010 | 04:46 PM
wannagetrdone's Avatar
I dont think it grounds itself when plugged in. Im not sure bout the mounting bolts not real sure where they mount to. Easy way to test is hook up a ground and see what happens. If still nothing at some point in time check make sure your gettin voltage. If its just for lights than yes you could come from the fuse box with a hot wire but still gonna have to have a ground of some sort somewhere.
Old Jan 15, 2010 | 05:26 PM
myyota's Avatar
You don`t need to ground the inclinometer, just wire it to a 12 volt source and it will work just fine.
Old Jan 15, 2010 | 07:58 PM
Van Cour's Avatar
which wire is ground and which is power?
Old Jan 15, 2010 | 08:07 PM
myyota's Avatar
I don`t know wich is wich, when i hooked mine up i spliced into the heater control light for power, and it works just fine.
Badlander
Jun 20, 2016 07:20 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
AkitaDog
Sep 1, 2015 08:05 AM
aviator
May 9, 2006 10:50 PM
gohawks
Apr 25, 2006 11:06 AM
