22RE throttle body (?)
Old Jan 3, 2010 | 04:57 PM
Oatmeal's Avatar
The throttle body on my 85' has worn throttle shaft bores (bushings?) causing it to not come down in idle speed unless you "blip" the throttle. This is causing issues (along with a bad cat) with the smog guys. I looked at getting a used one but, at about $150 and maybe no better than mine, I've been hesitant to go that route. Is there a way to rebush these things, is there a kit available? The price of a new one is through the roof and I can't even find rebuilts. I have about 330,000 miles on it (the throttle body, not the motor) and the cat as well (I guess it was due for replacement) Any help is appreciated. Thanks!----------Hans
Old Jan 3, 2010 | 05:20 PM
Teuf's Avatar
Can you take it apart and cut some shim stock to fit, ? It sounds like an odd area to figure out.
Old Jan 3, 2010 | 05:29 PM
myyota's Avatar
Check out www.nix99.com , ask for Josh, see what he can do for you. Tell him your a member here, it might get you a better deal.
Old Jan 3, 2010 | 05:41 PM
Teuf's Avatar
Thanks for that part link, I know it was for oatmeal but i'll check it out too.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
montanatruck
Feb 26, 2017 07:07 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
raiderhawks00
Jul 8, 2015 06:23 PM
