Broke something on my motor during rebuild
Old Feb 12, 2010 | 08:09 AM
subaruwrx88011's Avatar
When I was putting my motor back together I accidently broke this:
I think it was some kind of vacuum inlet/outlet.
Can someone tell me what this is and where I can get a new one?
Thanks,
Leon
Last edited by waskillywabbit; Feb 12, 2010 at 08:17 AM. Reason: Use more descriptive titles you will get more help
Old Feb 12, 2010 | 08:23 AM
4Crawler's Avatar
Looks like the Bi-metal Vacuum Switching Valve (BVSV) for the EGR system. It switches vacuum on to the EGR modulator once the engine warms up. Junkyard or Toyota parts counter to get a replacement:
- http://www.4crawler.com/4x4/index.shtml#VendorLinks
Old Feb 12, 2010 | 09:14 AM
THANK YOU SO MUCH!!!
I really appreciate it. I will search and see if I can find it.
Anyway you know a good way to find the part number for it? or is their any toyota employees on here that can get the part number for a Bi-metal Vacuum Switching Valve for a 1985 Toyota 4x4, 22re, non-turbo?
Thanks
Old Feb 14, 2010 | 02:29 PM
854x4's Avatar
If I remember right I think the number was either molded into the plastic peice that broke off or its etched into the brass fitting still there. I think those run about $80 at the dealer. If you need the part number I will try to get it tonight.
Old Feb 14, 2010 | 02:33 PM
1990yota-pickup's Avatar
good thing i got a extra in my garage
Old Mar 9, 2010 | 04:55 PM
will not fixing this right now make my truck not run. I am in the process of getting it running after a new timing chain and head and was wondering if this could be my problem?
Old Mar 9, 2010 | 05:11 PM
4Crawler's Avatar
Just affects the operation of the EGR valve. Basically blocks EGR operation until the engine is warmed up. With it broken, you'll have a small vacuum leak and depending on how you connected lines, the EGR will either be on all the time or off all the time.
bigjstang
Jun 2, 2025 03:56 PM
cars-guy
Aug 16, 2020 06:59 AM
oldirtydirt
Feb 23, 2020 09:30 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
karbin
Jul 5, 2015 11:37 PM
