PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31
  1. Help truck misfiring all the time and white grayish smoke comin out of exhaust
  2. Rear axle/differential problems
  3. 1985 4runner motor which one to rebuild
  4. 85 Pick Up Lot's of Play in Steering Wheel
  5. front driveline
  6. 82 to 85 interchangeable
  7. Frames?
  8. skyjacker or rough country
  9. 1st gen top
  10. weber carbs
  11. weber carbs
  12. 22re missing and power loss...I need ideas
  13. Question bout Smittybuilt Bumper
  14. trying to rig a kill switch..
  15. 85 22rec starting problems
  16. Axle Build
  17. Update: Blown Headgasket
  18. 22R oil change
  19. Is it possible to get this many mpg?
  20. 4runner tailgate window
  21. safc on a 22re
  22. redwolf3's '85 22RE Engine Rebuild Thread
  23. Which Weber Carb
  24. Truck pulls to right when braking??
  25. lift question...
  26. HEI for the 22r and 22rec
  27. valve seats
  28. 85 4Runner Engine Noise
  29. Steering knuckle arm removal help
  30. Cone Washer
  31. 22re getting hot
  32. throttle linkage cable?
  33. Manual Hubs??
  34. Fender Flares for 1st Gen 4runner (Not Bushwacker)
  35. Hub Rebuild thread
  36. 84 Toyota Brake Problems!!!
  37. 1985 4runner top leaking need new seal
  38. Front bumper design - Bored in class
  39. Timing chain guides.
  40. Different colored interior??
  41. Did some painting on the truck today...Pics
  42. Are these original the original mirrors?
  43. 4runner status!
  44. 93 rear window wont go down
  45. 1987 runner, no start, just click
  46. Skyjacker leaf springs
  47. Help Removing Autolocker
  48. Exhaust leak
  49. Tire balance
  50. major problems BVSV / vacuum / wiring...
  51. Death Valley Trip In Late June: Preparation Suggestions
  52. Piston hit head, what can I do
  53. Charge and Battery Light flashing
  54. Will not idle. Sucking Air. Too Lean at Idle.
  55. Carb help needed and diagrams
  56. my first truck
  57. Front Seal Replacement on 22R
  58. 84 Solid Axle rebuild..w/pictures :)
  59. multi-colored leaf springs!
  60. Front Springs
  61. 85 4 runner to truck swap
  62. Longblock switch-a-roo
  63. Optimal RPM range
  64. 22re fuel problem
  65. front axle help in Portland Or!!!
  66. Swap out a new axle or rebuild birfields?
  67. What is going on here?? Drum brakes on an 84
  68. 1984 Toyota Heating problems
  69. air conditioning?
  70. 85 4runner Shocks?!!
  71. Do I need ECU in 22r to run offroad?
  72. ecu and o2 questions.
  73. 85runner vibrations and slight grinding
  74. 22r idle problem
  75. 22R Idle Speed Screw?
  76. Negative side of coil?
  77. safety pad removal
  78. Heat Shield Needed?
  79. Brake power booster help?
  80. Help Quick! Rear Window Motor Wiring Harness
  81. electric fuel pump conversion
  82. How to put four link front triangulated rear
  83. will the TRD rims fit on my 85?
  84. PLEASE help need more power
  85. My new 4Runner
  86. 83 yota swapping a 22rec engine help problems ?
  87. WOW chains!!!!
  88. Pic Request 3" lift 31" Tires 4Runner
  89. Over heating...kinda
  90. My Runner Is Revving For No Reason :(
  91. Rear Bumper Choices
  92. Third gen 4Runner rims on first gen 4Runners?
  93. got my lift on!!!! 85 runner
  94. Vacuum/carb cut out problems
  95. clicking noise in sharp turns
  96. 22r carb...so bad?
  97. pop/hesitation
  98. 2wd rear end???
  99. Rebuild has a loud rattling on top
  100. 84 Knuckle rebuild w/bearings - questions
  101. Body Crack under the fender
  102. New 84 toy
  103. brake replacement front and rear for an 84 yota pickup
  104. Help smoke cominout of exhaust
  105. noob body lift ?
  106. hesitation no idea where its coming from???
  107. straight axle spindle?
  108. 84 with problems. Help please. (pics)
  109. 22RE Question Need Help
  110. Front Differental
  111. rough country lift kits
  112. Cammo 1985 Toyota 4runner!!!
  113. 85 toyota carb. need help!
  114. Injector issues, wiring Please Help
  115. Need info on 22RE-C Performace Camshafts
  116. Need help with 84 temp sender!
  117. T-Case help!!!!! Marlin 4.7 gears
  118. Clutch bleed and so much air
  119. 85 xtra cab driveshaft
  120. 85 4runner losing coolant
  121. Coolant Leak
  122. 85 Automatic 4Runner flywheel problem
  123. Coolant Sensor problems, help please!
  124. which plug do you check codes with????
  125. 85 yota cooling 350
  126. superlift quality?
  127. My truck: 1984 Pickup chevy lift
  128. 84-88 solid rear glass and 89-95 solid glass
  129. Drag link question
  130. Powersteering conversion
  131. 85 yota wont start -Wiring issue?
  132. 84 2WD loading up in carb?
  133. looking for a machine shop in nj
  134. would you buy (1984 Toyota 4Runner - $2000)
  135. 22r acting up
  136. high steer questions???
  137. fuel tank Q's
  138. Anyone want to help me do my axle seals?
  139. New Truck!!!!
  140. old ad for the 84
  141. Coos bay wheeler!!!!!
  142. no rear brakes?
  143. fuse diagram?
  144. Starting issue
  145. Bed Swap..?
  146. 1985 22r vibration
  147. Engine Trouble?
  148. rear axle sounds to me like the bearings are going out
  149. Low freon sensor, a/c cutout
  150. Easy ????
  151. Ill 22RE
  152. It was free 84 or 85 truck
  153. Timing Chain
  154. Birfield stub shaft retaining groove
  155. Soft rear springs. Stock length.
  156. Blown Head Gasket
  157. 85 4runner ecu problems
  158. Light Mounting
  159. 85 pickup engine
  160. 22R Will Not Idle All of A Sudden
  161. Going to buy a new engine, Which one??
  162. flex test
  163. pro comp lift install
  164. How to remove ANY crankshaft pulley bolt
  165. How hard, changing tranny
  166. Crankshaft pully bolt Help All Is Lost
  167. any ideas
  168. 1985 Pickup
  169. 84 lift kit pics
  170. Rust free bed
  171. 22R to 22R-E Conversion?
  172. Dual row chain toyota oil spline PN pre 85 block
  173. will not idle
  174. 84 pickup slave cylinder
  175. 22RE Swap Question
  176. suspension lift kit
  177. eating up connecting rod bearings
  178. Anybody got any good woodworking ideas for replcacing rear interior panels.
  179. spewing oil
  180. Engine Temperature not normal
  181. Water Pump issue?? Fan broke off shaft
  182. Code 6???
  183. coolant leak from hose under power steering pump
  184. reverse making some banging sounds
  185. LC Engineering Big Bore Throttle Body
  186. truss it or what?
  187. Injector wire color codes
  188. 5" lift
  189. Roof swap
  190. Back Door Warning Light -ON- Window Not Working
  191. Leaf springs?
  192. Quick Auto Trans Question
  193. Ideas on temporary Jerry can carrier please.
  194. Something binding up in drivetrain
  195. Did they make a 1985 IFS truck?
  196. axle cleanup!
  197. home made brake plate eliminator!
  198. 1985 4 runner Front Differential/Axle Leak
  199. 85 toyota 4 runner code reader
  200. Need Help ordering new Suspension Kit Today
  201. basket for an 85 runner
  202. 22-RE running problem
  203. 84 truck failed emissions
  204. burning water QQ
  205. Fuel Line Replacement
  206. 22r bolt up
  207. carb possibly vacuum?
  208. 85 4x4 with 22r carb
  209. Broken bolt in 84 yota, 22R oil pan, HELP!
  210. manual tranny swap
  211. 22re radiator in a 22r engine?
  212. 22r
  213. vacum lines
  214. swapping a 89 22r into a 85 pu 22r ??
  215. 4.70 transfer case gears
  216. Begining to get the Runner trail-worthy
  217. Engine codes pulled
  218. 5 speed tranny noise
  219. Pitch and roll on old 84 2WD
  220. Fixing Load Sensing Proportioning valve ?
  221. gears on an 85 p/u
  222. 22re running rich
  223. manual transmission shifting problem
  224. 85 4runner Auto Trans shifting problems
  225. 84 with front end damage
  226. Weber 36 Synchro Carb question?
  227. Mechanical to electric fuel pump?
  228. Air Pump what does it do...
  229. Overdrive Solenoid
  230. Finally found an 85 for cheap!
  231. Any threads on replacing throw out bearing?
  232. suspension ideas '85 pickup
  233. Pro Comp and Superlift 4 inch spring opinions?
  234. leaf springs
  235. New Yote Shop So Cal
  236. Do I need an IFS box to run hi-steer?
  237. What year did the make 22r with 2 roller?
  238. thirds swapping
  239. How can I find what year my block is?
  240. Doing a cab swap....Need advice
  241. Replacement Floor Pans
  242. Yet another gear ratio topic. 4.37 ?
  243. Work in progress
  244. 85 22re no crank, no turn over
  245. noise from front end
  246. 22R to 22RE - direct bolt in?
  247. Im new here and I have a nasty yota, but I need some help
  248. window not rolling up, take a look at pic
  249. '85 22re Suggestions - Top End or Full Rebuild
  250. Napa Part #'s for Axle Parts.
