suspension lift kit
Old Mar 23, 2009 | 10:09 PM
jc's_85toy's Avatar
suspension lift kit
Hi everyone, i am a new member to this forum. i have a 85 4runner with plans of picking up a lift kit. ive done extensive research and found all lift kits to be identical with the exception of springs(marlin crawler, all pro-offroad, trail gear, inchworm gear). these kits come in either 3", 4" or 5". Im not sure what size lift to get that would clear 35x12.50 tires(dont want to be too top heavy). i also want to upgrade all shocks from 5125's to 7100's, would i need specific shock hoops and mounts to use 7100's?
p.s. inchworm recommends using
larger springs in the rear if towing
Old Mar 24, 2009 | 01:09 AM
votum's Avatar
I had an '86 once that was fine stock with 32s. I have 13.50x35s now and a 5in suspension and 3in body, but no spacers so the tires rub. Don't think 12.5s would rub though. Go witht he bigger lift anyway, although my 86 looked badass all squat and fat
Old Mar 24, 2009 | 09:36 AM
94sasyota's Avatar
iam doing the same thing right now iam going with a 4in lift in the front and 63 chevys in the back i would go with a 12in hoop
Old Mar 24, 2009 | 10:28 AM
jc's_85toy's Avatar
are u running bilsteins 7100's also? .........i was looking at the 4inch lift but thought about the 3inch, a good friend told me running a 3inch would clear 35's and a 4inch would make my truck more tippy which i dont want.
Old Mar 24, 2009 | 10:30 AM
georgiayota's Avatar
I'd go with the 3in. What are you planning on doing with the truck?
Old Mar 24, 2009 | 10:57 AM
Ardent's Avatar
3" front, 4" rear. Gets rid of the sag. You might have a little trimming to do, but it would keep you low.
Old Mar 24, 2009 | 10:58 AM
desertcamper67's Avatar
I have a 3 inch lift along with longer shackles front and rear and 32's rub when I get twisted. I'd go with the 5 inch or do some cutting up front. You could do some custom bump stops to eliminate or minimize the rubbing during flexing.
Old Mar 24, 2009 | 11:05 AM
94sasyota's Avatar
no iam going to use the 5150's shocks and if you cut your fenders u should be good but i would still go with the 4in lift
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
Vargntucson
Jul 4, 2015 12:15 PM
