Hub Rebuild thread
Old May 2, 2009 | 07:58 AM
Outsane's Avatar
Hub Rebuild thread
Well here is the start of my hub rebuild thread..
I have ordered
Marlin HD seals
Marlin Heavy Duty Shifter Seats
Marlin Heavy Duty Shifter Socket
All-Pro KNUCKLE REBUILD KIT
All-Pro Front Wheel Bearing Kit
Rock-Ring Knuckle Felt Protectors
Back Plate Eliminator Kit
so I still need a brass drift, fish scale and 54mm socket.
and Grease..
This is all to get the rig ready to drive from San Diego to Big Sur with no issue..
After this I am planning on new timing chain, metal guides, water pump, oil pump.
Old May 2, 2009 | 04:08 PM
waskillywabbit's Avatar
Sounds more like a front axle rebuild.
Old May 2, 2009 | 04:26 PM
mikepr55's Avatar
I did my front axle rebuild a couple of monthes ago and it is realy eazy and such a relief on the mind now I need a drag link and clutch master and slave they are booth leaking..good luck on your trip..
Old May 2, 2009 | 05:41 PM
Outsane's Avatar
axle rebuild it is then..
It will be nice to know everything is solid..
Old May 3, 2009 | 12:34 AM
kcpanages's Avatar
with smiles like u must know my kin folk
Old May 3, 2009 | 07:31 AM
Wardamneagle's Avatar
I made this comment in another recent thread but it didn't seem to get any response. The birfield joints (and the trunion bearings) need moly-fortified grease. In the other thread, the OP had clearly used red Mobil 1 grease in the birfields. I'm sure you can get away with that but it isn't what is specified in the FSM. Both Valvoline and Amsoil make an excellent moly-fortified grease.
Good luck with the rebuild. It isn't that hard, just messy!
Old May 3, 2009 | 09:00 AM
Outsane's Avatar
I did see that...about the moly.. I'll be sure to get some moly fortified stuff..
Probably Valvoline, easier and cheaper to get then Amsoil
Old May 6, 2009 | 07:00 AM
Outsane's Avatar
got the Trail gear stuff
Old May 13, 2009 | 10:16 AM
Outsane's Avatar
Still waiting on All-pro and Marlin..
I did find a fish scale
Old May 20, 2009 | 10:53 AM
Outsane's Avatar
Got the All-pro stuff yesterday
and the Marlin stuff today!
now I need some moly fortified grease and some time
a garage, 54mm socket, and a brass drift..
Old May 20, 2009 | 06:06 PM
WVtoyjon's Avatar
Watching this intently as mine will need to be done before winter and I dont have the Cheddar to pay someone to do it.
Old May 20, 2009 | 06:31 PM
netwt12's Avatar
i hope you have a better time with your rebuild than i had installing my longs. i had to replace 4 mangled knuckle studs, 3 stripped hub studs, and one left handed tie rod end. you should also buy some of marlins inner axle seals. they are awesome.
Old May 22, 2009 | 12:35 PM
Johannes's Avatar
x2 on the marlin inner axle seals
Old May 22, 2009 | 02:41 PM
Outsane's Avatar
So a buddy is getting me some Amsoil moly!
WVtoyjon
As far as using this thread to rebuild I would stick with the pros..
http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
http://www.birfield.com/~morgan/tech/axle/index.html
http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
Hopefully with the amount of grease on there I won't have any issues..always the plan
Old May 23, 2009 | 01:19 PM
DoveGray85's Avatar
I'm in the process of rebuilding my 85 axle as well. It's going pretty well. I got the Marlin inner axle seals in for sure. I also did the Trail Gear knuckle gussets and a ring gear guard. That piece of armor seems very important because the front of the axle housing is pretty vulnerable to rocks. There was already a gouge in my housing where the ring gear fits. I beat it out with the brass bar and a hammer. The metal is pretty thin there.
Old May 23, 2009 | 06:25 PM
Outsane's Avatar
knuckle gussets would be nice addition to my build..
hmm...
Old May 23, 2009 | 06:46 PM
toyospearo's Avatar
I thought I might send this link along if you need any help...
https://www.yotatech.com/forums/f115...ctures-180536/
Old May 23, 2009 | 06:53 PM
Outsane's Avatar
Oh yeah read that thread!
Old May 23, 2009 | 07:00 PM
WVtoyjon's Avatar
God I love this website. Kick ass people and kick ass information. Great links all. Makes the impending work doable by even a half assed wrench like myself.
Old Sep 13, 2010 | 12:07 PM
Outsane's Avatar
finally started the Front Axle rebuild..
Drivers side is now disassembled.
