85 yota wont start -Wiring issue?
Old Apr 2, 2009 | 06:26 PM
Jhowe2k's Avatar
I have an 86 cab on an 85 yota which unfortunately gives me a lot of unconnected wires getting in my way. Problem is, last week the truck ran, and I decided to pull the 3" body lift off since it had split pucks etc. now I lowered it back to factory height and when I turn the key I get lights on the instrument panel, a click noise (which I assume is the relay?), but no starter engaging. I plan on simplifying the wiring (I want to rip the old harness out if I can since its an 86 harness and I have the 22r carbed engine. Any ideas on what this could be. I would greatly appreciate any help as this thing isnt moving at the moment. Looking at the side of the starter, everything appears to be hooked up. I have the thick wire going to the + terminal on the battery and the thinner black wire going to what I assume is the relay. Any help would be greatly appreciated.
(I don't mind bypassing the key tumbler or anything else. Push button is in the near future.)
-Jared
Old Apr 3, 2009 | 07:13 PM
Jhowe2k's Avatar
Found my problem. I hit the starter with a hammer and it must have had debris in it. Started right up. Of course I found out after web-wheeling for hours looking up wiring diagrams and checking the connections on the truck. Live and learn.
-Jared
Old Apr 4, 2009 | 12:11 AM
abecedarian's Avatar
One thing you may consider adding is a relay.
It'll save you wear on the ignition / key switch contacts.
Team420
Jan 12, 2021 04:57 PM
rbravo1
Jun 29, 2015 01:34 PM
serenity03k64
Jun 27, 2015 07:59 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
