22RE Question Need Help
Old Apr 8, 2009 | 02:45 PM
Thecarter999's Avatar
Alright Guys,
I have an 1985 Toyota ex-Cab and fairly new 22RE. I put new plugs,pug wires o2 sensor,and TPS in it. Also checked the the timming and its dead on. Checked vacum has no leaks, and check compresion and its good too. my problem is everytime i hook up the TPS it shuts off. If anyone has any idea of whats going on let me know.
Thanks Josh
Old Apr 9, 2009 | 07:44 AM
Jager's Avatar
This might be a dumb question, but did you get the tps adjusted right?
Old Apr 9, 2009 | 11:11 AM
Yea I got it figured out it's the mass air flow that's bad.
Old Apr 9, 2009 | 06:15 PM
Ok so i thought it was the mas air flow but its not. I did get the TPS adjusted right and it pluged up and idles fine. The truck cranks up fine idles fine but when you start to give it throttle its like its fooding out. and also it sometimes backfires. not sure what to do next cant seem to put my finer on the problem . Would the fuel filter on the block cause this? Im going to check it out tomorrow let me know if yall have some better ideas. Thank Josh
Old Apr 9, 2009 | 06:22 PM
TOYOTA 1's Avatar
im having the same issues on an 86 hmmmm.
scribed
Kiroshu's Avatar
Is there a check engine light on? And does it happen when its been sitting a while? If so you need to check your coolant temp sensor and the sensor beside it its the cold start time switch or somethin....
Old Apr 9, 2009 | 06:35 PM
The engine light is on i read the code and it is saying that i have a bad coolant temp sensor. im picking one up tomorrow but didnt think that would cause all my problem.
Old Apr 9, 2009 | 06:41 PM
Kiroshu's Avatar
ok where the coolant temp sensor is i have a hunch becasue this is what mine was doing the exact samething. have you messed with it before or recently? if so you mihgt have the wires mixed and or swapped try swaping them it my fix it and will cut the light out.... if not then you just got a bad sensor it will fix it trust me i had the exact prob.
Old Apr 9, 2009 | 06:56 PM
Thanks I'll let ya know tomorrow what happens.
Old Apr 10, 2009 | 05:21 PM
TOYOTA 1's Avatar
OK so i tested my thermo sensor, and sure enough it was bad. so i went to carquest and they had one in stock for 22 dollars and some change. installed the new sensor and wallah runs like a champ!
hope its an easy fix for you too carter!
thanks for the tip kiroshu!
Old Apr 10, 2009 | 05:37 PM
Awsome glad to here it fixed yours. I'm picking up my sensor up in the morning so cross your fingers I hope it fixes mine too I'll let ya know what happens.
Old Apr 10, 2009 | 05:48 PM
TOYOTA 1's Avatar
fingers crossed
Old Apr 11, 2009 | 06:29 AM
Ok so im running into another problem. No part store can give me the right sensor. My motor has only about 3,000 miles on it the only backgroung info i got is that it came frome Jasper Engines. Ill post some pics of my sensor and let me know if you know what year i could get a replacement. My sensor screws into the top of the thermostat housing. Thanks
Old Apr 11, 2009 | 08:20 AM
TOYOTA 1's Avatar
thats not the thermo sensor, at least not the one i changed..
the thermo sensor is on the front portion of the lower intake. theres two there, the one on the right(facing the motor) is the thermo sensor! the other is the cold start injector time switch..
hope that helps..
Old Apr 11, 2009 | 08:40 AM
ok thanks ill check it out and get back to ya
Old Apr 12, 2009 | 02:44 PM
ok guys changed out the sensor and now it still wont run good it didnt fix it. Cranks up fine idles fine just wont rev up with out bogging down. Could it be the fuel filter on the block? It just seems like its starving for fuel when you give it more throttle. I know its not the pump cause i changed it out last year. Just let me know what yall think.
Old Apr 12, 2009 | 02:54 PM
4Crawler's Avatar
That sensor (atop the t-stat housing) is typically to cut out the A/C if the engine gets too hot. Is there a vacuum line connected to the fuel pressure regulator?
Old Apr 12, 2009 | 03:07 PM
yea i looked it up. and yes all the vacume lines are hooked up in the correct locations iv printed off a diagram and made sure they were. also check the vacum and there are no leaks. The part store has a fuel filter in stock im going to get it and see if that helps.
Old Apr 12, 2009 | 07:12 PM
Exclamation
Ok im Stumped!!!!!!!
Ill start from the top:
I took my 85 EFI 4Runner cab off and swaped it with a 85 EFI Ex Cab. Now im not sure whats wrong.
Ive changed:
*Fuel Filter
*Fuel Lines
*Plugs
*Plug Wiers
*02 Sensor
*Temp Sensor
*TPS
* Mass Air Sensor
Its still doing the same thing. It idles fine just whaen you give it throttle it wants to skip and backfire. This thing is driving me crazy i think if i cant figure this out soon i may have to call in a toyota technician for help. Ill take any sugestion so keep them coming guys i appriate the help.
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
