Mechanical to electric fuel pump?
Old Mar 7, 2009 | 06:31 AM
resiewdub's Avatar
Anyone ever switched out the fuel pump from a mechanical to electric? I just got a weber carb and it calls for 3 psi, which is less than mechanical puts out. I could get a regulator, but why not just go electrical? Could I get a pump from the junkyard, or auto parts store? How would I wire it in?
Thanks in advance!
Old Mar 7, 2009 | 08:45 PM
myyota's Avatar
It would be cheaper and easier to just get a regulator and hook it up, otherwise your looking at buying an electric fuel pump and wiring to make it work, and you still might also need a regulator even with the electric pump, it just depends on how much money you want to spend and how much work you want to put into it.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
