2wd rear end???
Old Apr 11, 2009 | 03:08 PM
white93yota's Avatar
2wd rear end???
does a 1993 toyota 2wd pickup have a posi or a lsd in the back???
Old Apr 11, 2009 | 05:00 PM
TrikeKid's Avatar
Nope. I think you can make one from an early Supra work. Check out the forum on Toyota Minis, that site's all about 2wd stuff and might be a little more helpful to you.
http://www.toyotaminis.com/forum/index.php
Old Apr 12, 2009 | 06:38 PM
deserttoy84's Avatar
toyota pickups never came with a posi. If you have a 2wd 5 lug it's prob a 7.5 diff and you need a posi out of an 82-86 supra(mark II). If it's an 8" (4wd or some 2wd trucks) You need the posi out of an 86-92(mark III)
Old Mar 1, 2011 | 12:50 PM
SlightlyWhat's Avatar
So im looking for the same type of this...I just take the rear gear out of a 82-86 supra??? it should have a LSD. I have a 89.5 pickup. 90 i guess standard cab.
Old Mar 1, 2011 | 02:13 PM
MudHippy's Avatar
You have to makes sure it does. Some do, some don't.
And there's some that have different gear ratios than PU's(namely 3.73s). But, you could swap the ring and pinion with yours if you needed to.
It can have 5 lugs and an 8" too. So you need to make sure it's the right size before looking for either.
Old Mar 1, 2011 | 08:57 PM
Alright I'll keep that in mind and look at the code as well.
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
Daneums
Aug 20, 2015 05:36 AM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
