Fuel Line Replacement
Old Mar 14, 2009 | 05:07 AM
Dan.3's Avatar
So I have fuel seeping out of my rust of the metal fuel line at the junction of the rubber house from the fuel pump. Anyone ever run a steel braided fuel from the pump to the filter. I just found it this morning letting my truck warm up for a trail run. I dont feel like assessing the situation yet. Im going to let the temperature warm up first. Just thought I would post to see if anyone has any experience with this.
I should be ok just running a rubber fuel line but i want to get a steel braided one so I can coat it and prevent this from happening again.
Old Mar 14, 2009 | 01:44 PM
myyota's Avatar
Braided fuel line will work just fine.
Old Mar 14, 2009 | 04:55 PM
86tuning's Avatar
So will regular fuel hose. Which is much cheaper and easier to install.
Old Mar 14, 2009 | 05:11 PM
Dan.3's Avatar
I think thats what I will end up doing. Ill probably spray some under coating on it to help give it better protection from elements. Anyone happen to to know what size fuel hose to get? I dont want to run to small or to big
Old Mar 16, 2009 | 08:10 PM
86tuning's Avatar
Eeeek. Is your rig EFI or carbureted? Because regular rubber fuel hose is a no-no for EFI applications after the fuel pump. On a carbureted rig that runs low fuel pressure, regular fuel hose is fine fine fine.
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
