85 4runner Auto Trans shifting problems
Old Mar 8, 2009 | 03:20 PM
midyetteracing's Avatar
I have a 85 4runner and it seems like when you take off its in second then doesnt want to shift to 3rd untill u hit the overdrive button then goes to overdrive when you hit again it comes back to third. who i got it from told me that the soleniods had been replaced i dont have any idea what could do this . . the check angine light stays on as well was also told that the engine computer has been replaced and the lights still stayed on . . idk if that has something to do with it. can any one helpppp???
thankss
SHAWN
Old Mar 9, 2009 | 05:37 AM
texcat101's Avatar
I would think it best to run the codes on your engine first. After you have determined why your check engine light is on ( and repaired the problem ) you will be in a better position to diagnose the tranny.
With computer controllers it's always-"junk in junk out".
Old Mar 9, 2009 | 06:33 AM
where is the hook up for puttin a scan tool on it to check the codes?
Old Mar 9, 2009 | 07:03 AM
Dan.3's Avatar
Here is the scan tool you will need to purchase.
You use this in the engine bay. Good luck
Old Mar 9, 2009 | 02:49 PM
4runnerx3's Avatar
Does the OD light blink?
Old Mar 10, 2009 | 07:03 AM
the OD light does not blink but it does work when u hit the button to turn it on it goes out but when u hit again it comes on and says off but doesnt blink or flash
Old Mar 10, 2009 | 07:28 AM
yodercrawler55's Avatar
my light doesn't even work, im currently having problems with the tranny going in overdrive too quick
Old Mar 12, 2009 | 06:21 AM
what does it mean if the light is flashing or not
Old Mar 12, 2009 | 04:52 PM
4runnerx3's Avatar
If it's blinking you have stored codes in the ECT unit.
To get it to flash the codes, you need to ground the small square plug on driver fender.
switch ignition on without starting and OD must be on.
Old Mar 13, 2009 | 03:27 AM
well if it aint blinkin does that mean it aint electrical or could be electrical just not in the computer?
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
BLRobertson
3.4 Swaps
Jul 10, 2015 04:27 AM
Ron(Fla)
Jun 20, 2002 07:04 PM
