85 4runner Auto Trans shifting problems
I have a 85 4runner and it seems like when you take off its in second then doesnt want to shift to 3rd untill u hit the overdrive button then goes to overdrive when you hit again it comes back to third. who i got it from told me that the soleniods had been replaced i dont have any idea what could do this . . the check angine light stays on as well was also told that the engine computer has been replaced and the lights still stayed on . . idk if that has something to do with it. can any one helpppp???
thankss SHAWN |
I would think it best to run the codes on your engine first. After you have determined why your check engine light is on ( and repaired the problem ) you will be in a better position to diagnose the tranny.
With computer controllers it's always-"junk in junk out". |
where is the hook up for puttin a scan tool on it to check the codes?
Originally Posted by midyetteracing
(Post 51082786)
Here is the scan tool you will need to purchase. http://i24.photobucket.com/albums/c7.../paperclip.jpg You use this in the engine bay. Good luck |
Does the OD light blink?
the OD light does not blink but it does work when u hit the button to turn it on it goes out but when u hit again it comes on and says off but doesnt blink or flash
my light doesn't even work, im currently having problems with the tranny going in overdrive too quick
what does it mean if the light is flashing or not
If it's blinking you have stored codes in the ECT unit.
http://i22.photobucket.com/albums/b3...4RUNNER447.jpg To get it to flash the codes, you need to ground the small square plug on driver fender. http://i22.photobucket.com/albums/b3...4RUNNER005.jpg switch ignition on without starting and OD must be on. |
well if it aint blinkin does that mean it aint electrical or could be electrical just not in the computer?
