22R to 22RE - direct bolt in?
Old Feb 28, 2009 | 01:47 PM
84darknight's Avatar
I found a 1990 22re will there be room to put it in my 84 22R truck if i wanted
Last edited by waskillywabbit; Mar 1, 2009 at 03:27 PM. Reason: Yes, they are the same basic engine
Old Feb 28, 2009 | 01:56 PM
TOYOTA 1's Avatar
oh man, since your from Oregon ill take it easy on ya lol.
you need to post more info than that. the more info we have the better we can help!
Old Feb 28, 2009 | 01:58 PM
hillbillydeelux's Avatar
no relevence to the post
oregon yotas run better than any other
Old Feb 28, 2009 | 02:27 PM
nice hillbilly, I dont have anymore info than the info that i gave my 1984 toy has a 22r in it i didnt know if the new engine would take up more room or not
Old Feb 28, 2009 | 02:46 PM
1989toy4wd's Avatar
well we didnt know if you meant room in the bed, cab, etc or what type of truck, etc...but now that I know that, yes you can fit one in your truck, it should be a direct bolt in if im not mistaken, but your truck is carberated and if you want to make it fuel injected like the 22re, then you need the computer, all the sensors, and maybe the guage cluster!!
There were some differences in the 22rs over the years, an I am not familiar with all of them, but I do think that this is a direct bolt in!!!
Old Feb 28, 2009 | 03:09 PM
I have a 1984 standard cab long box 4x4
Old Mar 1, 2009 | 02:18 PM
abecedarian's Avatar
The longblock (block and head) itself will bolt in with few if any issues. May have an issue with the oil pan and pick-up tube if the new engine is from a 2wd so you would need to change those from your engine to the new engine if that's the case.
If you try to keep your carb'd setup you may run into some issues with the intake and exhaust manifolds being different (exhaust in particular)- there may be a stud or two that need relocated on the intake, you may not have all the water passages on the carb'd manifold that the efi cylinder head has and the exhaust ports are different on the heads so you'd need the newer exhaust manifold. You'd also need to pull the valve cover off the two engines and move the fuel pump eccentric from your engine to the new engine (take the thick washer out of the 22re first) and remove the fuel pump block-off plate from the 22re, and use your distributor.
If you're going to convert yours to the EFI, you'll need the harness, ecu and everything in between from the donor truck, or comparable.
Old Mar 1, 2009 | 02:54 PM
brownbagg's Avatar
its the same motor, just fuel injected
Old Mar 1, 2009 | 03:55 PM
yeah i was just a little worried that the newer engine would be to big i get to look at it tomarrow so
Old Mar 1, 2009 | 08:10 PM
a 1990 22re is not the same as a 1984 22r. they are similar: they share the same transmission bolt pattern, crankshaft and rods, and engine mounts. that does not make them the same.
already addressed that in my post above, as have other commented on it above
Old Mar 1, 2009 | 08:47 PM
91Toyota's Avatar
I'm sure that guy's wife is ugly...all women are the same right?
Old Mar 1, 2009 | 08:49 PM
rowdy235's Avatar
IIRC, though the 81-84 and 85-95 22r(e)'s are different, if you swap the WHOLE ENGINE, it will work out fine.
Old Mar 1, 2009 | 08:50 PM
91Toyota's Avatar
Hey Rowdy, hows the new truck? What color is it anyway...wonder if I've seen you around
Old Mar 1, 2009 | 09:41 PM
yeah its a whole engine swap not just parts
Old Mar 3, 2009 | 04:24 PM
Is there a difference in a car 22re or 22r for a truck in other word car i out a car engine in my truck
sandyota
Feb 4, 2021 11:16 AM
jjrbus
Jul 17, 2015 07:06 AM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
87blyota
Jul 10, 2015 04:31 AM
