PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Throttle sticking.. Gas pedal?
  2. Truck just died!!
  3. Center Support Bearing
  4. Timing jumped?
  5. Universal center consloe
  6. Ac comp replace Q's?
  7. I am now the proud owner of something...
  8. gas in oil what do I need to check
  9. 85 SR5 4x4 xtra-cab yota truck, what to do?, motor bad
  10. Wanting to piece together an '86 and '85
  11. Going from a G52 to a top shift W56-B
  12. New leaf springs now steering rod hitting Ubolt?
  13. 85 missing/rough idle when warm.
  14. What would cause oil in the Radiator?
  15. Change to a different alternator
  16. Auto Tranny Rebuild Kit Help
  17. 85 22re needs help apply within
  18. Starting leaf spring swap this weekend, and I've got a couple questions...
  19. front end diagnostics
  20. 85 crossover steering
  21. Heavy oil leak? rear main?
  22. '85 stock differential gear ratios
  23. 2wd or 4wd bed
  24. lc stage four cam
  25. 8" Differential Gear Mesh
  26. 85 4Runner grinding noise on turning
  27. 1985 22re Motorhome where to put jack?
  28. Thinking about buying a 1985 non turbo diesel
  29. got a oil leak, got pic's
  30. 22R knocks when warm ?
  31. clutch compatablility 4wd and 2wd
  32. Broken TPS or Broken User?
  33. Fuelgauge shows 1/4 after 100 mi from full
  34. 22RE Wont Start warm HELP
  35. Need some electrical help 85 p/u
  36. vacuum lines and timing issues, Help
  37. 2nd Gen Seat Swap: FYI
  38. Where to put grey sealer on timing cover?
  39. Understanding fuel consumption?
  40. Gear oil in locker air line
  41. bad death wobble
  42. 82 guts and axles on an 85 4runner
  43. Starting Issues? Try this...
  44. Fuel pressure
  45. Shock Reccomendations
  46. Coolant Temp Gauge
  47. 1985 toyota pickup 22re sometimes starting issues
  48. Wheel Bearing preload
  49. My first runner 85 efi fsa build up
  50. Thermo sensor touching catalytic converter element....s'ok?
  51. How do I know it's I have a sr5 runner
  52. Looking for suggestions: 22R/Weber carb Snorkel Ideas/Alternatives
  53. G52 to w56 swap...
  54. 85 Skyjacker 5" kit with rear leafs
  55. 85 4runner vin plate RN65 and frame has RN60 ?
  56. Just so I'm clear on gears...
  57. Chase rust or swap cab
  58. 1985 Toyota Pickup FSM
  59. 84 with no brake lights
  60. new to toyota. best places for parts?
  61. 22R temp question...
  62. axle shims
  63. Black oil
  64. Air intake/battery swap
  65. 85 pup thrown rod. Sell/part out or fix it?
  66. 35s with no lift?
  67. Advice needed: fix, sell, part out?
  68. No crank problem
  69. Seafoam engine treatment as a diagnostic tool?
  70. How to Verify Gear ratio without taking your diff apart
  71. Egr block off procedures
  72. Does my power steering pump need rebuild?
  73. can't get into gear
  74. Head light on but dash and tail lights off
  75. Considering replacing 85 Toyota 4wd Longbed frame with 85 2wd Longbed,Will this work?
  76. Reciver for hitch in front of 4runner ???
  77. 1984 ttoyota sr5, carb issues
  78. Is my coil bad?
  79. HELP! automatic tranny stuck in first gear
  80. '85 Pickup a few questions
  81. Incessant drive-train squeal. Cannot figure it out.
  82. 1986 22r Intermittent Hard Start, Turns Over, Ignition Related.
  83. weird grind when turned off
  84. rhino liner removal?
  85. Engine swap question 22rec -> 22R? +auto trans?
  86. Dual Case Question
  87. Bypassed ignition coil kill switch, now no start
  88. 1985 22RE Running rough
  89. Another head gasket question
  90. Spring question
  91. needing some help with brakes
  92. Suspension rebuild help
  93. 85 4runner sitting for over 10 years Q&A
  94. 85 22r How to check Ignition control module?
  95. 1986 4runner 22re rebuilt HELP!
  96. Quick axle install help.....
  97. Fuel line?
  98. Nippon Racing Aluminum Radiator
  99. checking wiring for the coolant temp sensor (EFI)
  100. Crank pulley/22r
  101. Are non-SR5 electrical harnesses the same as SR5?
  102. hydro assist
  103. caster angle
  104. Wondering about installing an oil cooler.
  105. 1985 22RE Hard Start, Runs fine
  106. brakes rub.
  107. Truck starts but wont idle
  108. Vinyl or Carpet for my cab
  109. Leaf Springs
  110. Nearly ready to pull the trigger on assembled 3rds
  111. 1985 4x4 axles
  112. My search is over! Found my 4Runner Lookalike Camper Shell
  113. Interior color opinion needed!
  114. T1 connector?
  115. Clutch disc size?
  116. Oil sending unit?
  117. Soft Camper
  118. shorter torque rod after lift?
  119. front end clunk
  120. 1985 pickup 22RE missing O2 Sensor???
  121. 85 pickup crazy wandering
  122. Cracked tranmission fill bolt hub
  123. 85 yota SR5 - rebuild or drive til it dies?
  124. a430d
  125. Regearing transfer case and I have a dual stick question
  126. 1985 loss of power above 3/4 throttle
  127. Cold weather carb(?) problem
  128. front torque rod / track bar
  129. Best way to clean knuckle balls?
  130. Lifting the 85
  131. 4 inch lift using springs? what do you have?
  132. SFA camber in chewing up tires!
  133. 85 4runner , how far does slave cylinder have to move clutch fork to fully disengage
  134. Fuel Injector question
  135. 84 22r timing, discrepancies in manuals and many forums...
  136. Just a pic of my youngest
  137. Pitman arm
  138. How much is it worth
  139. Trail gear front lift 5" pinion issues ???
  140. 85 front axle? did I do it right? any help appriciated!!!
  141. Rubber hoses 22re
  142. front solid axle rebuild
  143. IFS Skid Plate for 86runner
  144. 1985 hanger bearing dust shield
  145. I’m getting locker up what should I do ?
  146. rear 3rd member replacement
  147. Need part number for Clevite 77 Main and Rod Bearings
  148. Compression test...one cylinder down..leaking head gasket... rebuild or not
  149. Sbc swap header/motor mount problem
  150. my Truck hesitates when driving
  151. Help! Changed timing chain - did I crunch my valves?
  152. Gear oil drip on lower part of rear drum brake?
  153. Whats it worth?
  154. Random starter failure
  155. Where I'm at, and where I want to go...My 84 xtra cab build...
  156. Clutch Wont Disengage
  157. Oil sending unit ?
  158. ALT and External regulator question
  159. ideas for my 85 build up
  160. 1985 Toyota Pickup high idle and stumbles
  161. Choke wont close...can't figure this one out!
  162. Number of splines on '85' 4Runner frt axle
  163. Has anyone done carb to megasquirt conversion?
  164. regon engine builders? superstock 22r? valve lash?
  165. knuckle rebuild...best brand
  166. 87 22re odd startup/idle issue
  167. 85 4runner doors same as 89?
  168. Ect
  169. Whats needed for a 3 in body
  170. Rear main & Rear ou put seal blown in a month?
  171. Suspect aisin carburetor issue.
  172. 5 spd shifter issues
  173. 1985 22R 5 spd shifting problems
  174. 1985 pick up rear axle bearing replacement
  175. Front drive shaft doesnt spin freely when transfer case is not engaged
  176. Anyone have any megasquirt files I can use for startup?
  177. Why do I keep blowing my EFI circut fuse?
  178. Float level help. :/
  179. 1984 Toyota 4x4 22re diagnostics plu
  180. 1984 22r egr/vacuum line delete
  181. Vacuum Line Help! (PICS)
  182. weber install help!
  183. 85 pickup fiberglass body repairs
  184. 85 ride height
  185. head to header bolt holes stripped
  186. Pics of front plate winch bumpers
  187. fuel pump fitment?
  188. NEED HELP 84 pu 22r cold mixture heater assbmly
  189. weber linkage problem
  190. problem with heater
  191. 1985 22RE Won't Start. EFI Temp Sensor?
  192. How To: 1985 4Runner Heater Core Removal
  193. Do simple step-by-step instructions exist for NON mechanics on how to rebuild a 22R?
  194. 1986 sr5 turbo x cab bed cover question
  195. Just finishing up Dual's, Just need a skid plate.
  196. Full fuel glass.
  197. New motor misfire problem:feed up
  198. Aisin hub spring
  199. running rich and i dont know why
  200. no number. 3
  201. Front leafspring bushings.
  202. 1985 Bed Swap
  203. 1985 Pickup Suspension question
  204. 1984 4X4 Pickup 22R install aftermarket tachometer NEED HELP!
  205. 22r excessive cam wear: opinions on stupid cheap rebuild
  206. 22re sr5 temp guage
  207. Rotor sticking?
  208. power steering conversion
  209. 22re idle lowers with truck in neutral clutch disengaged
  210. bent axle??
  211. Brake problems
  212. military box carry alongs
  213. possibly buying an 85?
  214. 4.7 t case roar
  215. 87 4runner transmission whining
  216. manual or power steering?
  217. Feels as though it will shake to pieces
  218. "Popping" noise when turning.
  219. Where can I find wire mesh headlight guards?
  220. Head gasket or water jacket?
  221. 1985 22RE hard to start when warm/hot rough idle...tried all the "Fixes"
  222. My new '85 Pickup
  223. gauge cluster
  224. 1987 Pickup not running right
  225. Out of coolant with no leaks!
  226. 85 22re power without touching the bottom end?
  227. ignition coil
  228. ignition coil wires
  229. Home made turbo set up 22r
  230. Rear Window Problems
  231. Snorkel/air box ideas
  232. 1985 toyota pickup, runs rich
  233. Running hot with new parts
  234. New toyota - Total newb - Restore it or walk away?
  235. First post/ First yota
  236. 86-89 4runner body lift work with 85?
  237. 85 p/u 22re HARD to start HOT or COLD!
  238. curiousity, wider axles that fit 1st gen 4runner thirds?
  239. second gen extra cab rear bench
  240. 85 Tranny Swap
  241. Help me clear 33x14.50 boggers for my 85' 4runner?
  242. Steering shaft compression
  243. Electical Issue
  244. lost 1st gear on 5speed manual
  245. power window regulator options?
  246. missing plug and green/red wire????
  247. Vacuum line elimination help
  248. !!! help!!! 84 carb no start
  249. Outer snap ring part number
  250. 84 carbed 4x4 will not start
