1985 22R 5 spd shifting problems
Old Jan 4, 2013 | 08:06 PM
WJ27's Avatar
I need your help guys I don't know if this is normal or if it broken. A little background it's a 1985 reg cab base model 22R 5 spd with 209xxx. It's the ugly off white color and it has a red topper ( for now).
Anyway so I shift it and it shifts fine between 1 and 2, but when I go to shift to 3rd it stays in 2nd and the shifter just can move absolutely anywhere it wants, but this is only due to the small amount of vertical pressure I put on it shifting to third. Basically why is it that my shifter can be lifted upwards and disengaged so to say. How do I fix this? First post
Old Jan 4, 2013 | 08:19 PM
rokblok's Avatar
I would check the shifter seat and ball. They're pretty common about wearing out. Not saying that's the issue, but its a relatively easy, cheap fix, and worth a look. A little searching will tell you all you need to know...
sandyota
Feb 4, 2021 11:16 AM
adammtb
Jul 27, 2015 11:57 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
