a430d
Old Feb 7, 2013 | 05:44 AM
timgriffith's Avatar
a430d
Hi I am new here and am hoping someone can answer my question.
I have a 1985 toyota 2wd pickup with a 22re. it is an automatic and up until just a few days ago was shifting great. then it started not wanting to go into overdrive unless while I am driving i slip it into neutral shut the key of restart and put back into drive. after that the tranny will work fine until I shut it off I done alot of basic diag and have come to the conclusion it has to be the overdrive relay. where is the overdrive relay they show it in the wiring diagram . I cant find any location info. i have check overdrive switch, tps, thermostat. Thank you everybody for you assistance.
Old Feb 7, 2013 | 06:05 AM
waskillywabbit's Avatar
Isn't it under the center console above the shifter towards the dash?
:wabbit2:
86yota2wd
Nov 19, 2013 08:06 PM
