weber install help!
Old Dec 30, 2012 | 09:24 AM
ojm3's Avatar
weber install help!
Hey guys litterally sitting here with my carb off trying to figure out how to install the adapter plates to slap on a weber. I know which plate goes to the manifold, and which plate goes to the carb. but the studs on the manifold do not match up idk why its the kit for the 22r for sure! Please help!!!!
Old Dec 30, 2012 | 03:28 PM
ojm3's Avatar
I figured it out. FYI for any newbs like me installing a webber...You have to remove the stock studs in the intake manifold. I used some PB Blaster, locked onto them with some vice grips, sprayed the PB, wiggled the stud north, south, east, west, tapped the top with a hammer and shook 'em loose. When you mount the adapter plate to the manifold adapter you will insert the 4 new studs. Put them in tight, but be sure not to tighten the studs too tight and raise the adapter off the other adpater. Then you will break them like i did.
kazuya2416
Apr 5, 2024 02:17 AM
nvdesertrunner
May 11, 2020 08:18 PM
God's Bounty Hunter
Oct 23, 2015 09:44 AM
priest16
15
Aug 6, 2015 07:43 AM
mikeyd6789
Aug 4, 2015 11:51 AM
