Crank pulley/22r
Old Feb 17, 2013 | 06:41 AM
84SR5's Avatar
Crank pulley/22r
Is there a difference between a dual chain pulley and a single chain pulley for 22R's? As far as the part of the pulley that goes into the seal / lenght?
Any info on this would be great, thanks!
Old Feb 17, 2013 | 10:11 AM
Dale Rosales's Avatar
yes I think there is, but if somebody knows for sure please correct me! (please be gentle) lol Ok well I've was told (sales rep at LC engineering) when I changed out my timing kit from single chain to double chain kit that the early 22 R Block has a thicker timing chain cover like the 20r engine so an early 22r engine will accept a dual row timing chain with no other parts needing to buy as for a late 22 R (85-9?) has a thinner timing chain cover so therefore will only accept a single chain set up unless you purchase a different timing chain cover (early) that is thicker and you also need longer bolts to go with (single chain cover bolts are too short now) that because the timing chain cover is thicker now so you're bolts will be shorter. Ok that's all I got for that lol hope that helps
Sent from my ADR6400L using YotaTech
Old Feb 18, 2013 | 06:06 PM
84SR5's Avatar
Dale you were half right , the problem I was having turns out to be the oil pump housing. It seems that there are 2 oil pump housings one short snout and one long,I had the long and my pulley is for the short one and it was lightly rubbing up against the housing when tightened down, I switched it out today and problem solved. I needed the short pump housing. Thanks
Old Feb 18, 2013 | 10:43 PM
Awesome you figured it out so you can enjoy your rig bud. I'm glad I could half help lol I guess that's better then nothin but now from what you said I'm thinking I forgot to mention the drive spline? and that's probably what you were talking about and I just didn't get it hahaha silly me...Well anyways like I said awesome you fixed it
JonG85
Jan 18, 2023 04:31 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
gentry
Sep 28, 2015 06:16 AM
