Random starter failure
Old Jan 17, 2013 | 09:30 PM
Capt. Red Beard's Avatar
About 1 outa 5 times the starter in my 86 just doesn't work. You turn the key, and just hear a click from the starter, that's it.
I think the battery is good. Any ideas on what this may be? The guy I just bought it from recently replaced the starter, and alternator.
Old Jan 17, 2013 | 09:36 PM
rokblok's Avatar
Check all connection and ground points. Then have battery load tested. Then possibly starter relay, starter, ignition switch, etc.
Old Jan 17, 2013 | 11:48 PM
vital22re's Avatar
totally a bro
Check the voltage at the starter signal wire. Often it barely puts out enough volts to engage the solenoid. I've rigged a relay using that wire to make sure the starter gets a full 12v at the solenoid.
Old Jan 18, 2013 | 08:45 AM
Vital22re, I'll check that. How did you rig up a relay like that?
Old Jan 18, 2013 | 11:48 AM
4Crawler's Avatar
Test:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
Fixes:
- http://www.4crawler.com/4x4/CheapTri...rter.shtml#Fix
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Old Jan 18, 2013 | 08:15 PM
Perfect. Thanks.
ladybugRC
458
Aug 21, 2020 10:41 AM
shredder4286
Oct 1, 2015 01:09 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
Shagool22
Sep 28, 2015 07:53 PM
