ignition coil
Old Dec 2, 2012 | 06:07 AM
ojm3's Avatar
ignition coil
hey guys im trying to replace my ignition coil with an aftermarket product. Problem is out of the white and black wires i do not know which is pos, and which is negatgive. Any help would be much obliged!! im stuck at the house till its fixed.
Old Dec 2, 2012 | 06:24 AM
brianh699's Avatar
What year? Engine?
Old Dec 2, 2012 | 06:58 AM
brianh699's Avatar
Looking through wiring diagrams, you should have two wires coming off ignitor one black(ground) and one black with red stripe(positive). The only white wire I see runs from the pickup coil in distributor to ignitor.
Old Dec 2, 2012 | 03:50 PM
ojm3's Avatar
Thank you sir but i figured it out lol. I went a bout a 6 dollar test light and hooked it up. Turns out that red line in the white wire over the last 27 years has turned it pink! haha. Just gave her new high end wires, plugs, and a performance accell coil, UNREAL it just gave me no joke 30 more hp, and cured my high idle. Last owner didnt take care of her she was chock full of junk with bad fluids and plugs nearly 5 years old.
Old Dec 4, 2012 | 02:14 PM
Dale Rosales's Avatar
30 more HP Really?
Old Dec 4, 2012 | 03:00 PM
ojm3's Avatar
id say its the least amount i gained. Put it like this, before the ignition top speed was bout 70 with 33's. Now i can rip past 80 easy. And i have about a 150 foot incline that stretches over 500 feet on the way to me house. In fourth gear before new ignition i lost speed and almost had to downshift. Now im GAINING speed on the same hill!
Old Dec 4, 2012 | 05:09 PM
Wow that's awesome man! I'm going to pick one up soon and hopefully I get the same results, thanks for the tip
Old Dec 4, 2012 | 06:01 PM
toastyjosh's Avatar
which accel coil did you use?
Old Dec 4, 2012 | 07:18 PM
Ok so I went out a bit ago after chatting here and check the status of my factory coil. and as it turns out it's worn out, the primary resistance was on the low side of factory spec 0.8 ohms and the secondary resistance was 9.2 k ohms below Factory spec of 10.7-14.5 k ohms so this will help my little yoda! Good luck with your truck buddy
Old Dec 5, 2012 | 05:54 AM
ojm3's Avatar
Dale Rosales glad you caught the problem that coil should do wonders...get some promo wires n a good distributor cap n rotor with brass contacts while your at it. I promise it'll do wonders! Toasty Josh ill let u know when I take a look after work.
Old Dec 5, 2012 | 03:00 PM
toastyjosh's Avatar
From ojM3
accel coil called "super stack" coil #61400. I went to autozone n this was what the computer calls for as an aftermarket upgrade.
Old Dec 12, 2012 | 12:12 AM
Ojm3 I just picked up that coil and installed it. I like it but the coil gets really hot is yours getting hot to? Or does anyone know if this is normal??? I have a 84 early 22R
Old Dec 12, 2012 | 04:55 AM
ojm3's Avatar
Dale Rosales. My coil runs cool. I also replaced the cap and rotor, and wires with newer ones that have all brass contacts. It is absolutely essential that you keep all of your wires from contacting each other and metal with a coil that powerful and new parts you definitely will arc off which can cause your coil to run hot
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
voiddweller
Sep 28, 2015 11:21 PM
mojo4x420
Sep 16, 2015 08:07 AM
JHalcyonM
Sep 14, 2015 01:10 AM
