85 4runner , how far does slave cylinder have to move clutch fork to fully disengage
hello ,I have a 85 4runner , I was wanting to know how far does slave cylinder have to move clutch fork to fully disengage so when stopped you can put into first gear . im having trouble sometimes getting it into first gear when stopped..thank you .
i'd check for ya, but i dont got anyone here to push the clutch while i measure lol
any signs of leaks at the slave or on the inside of the firewall from the master?
any signs of cracks on the peddle assembly?
i just bought a new toyota oem slave and master cylinder bled them didnt help , bracket is ok , the clutch doesn't slip .I did adjust free play . what it might be is the push rod is not pushing the clutch fork enough to fully disengage
http://www.1stgencelica.com/viewtopic.php?f=11&t=15270
check for clutch fork free play/movement.
don't bother dropping the tranny until its the last option you can think of like me...and if you do, just pop in a new clutch kit while you're in there
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
09-09-2015 06:24 AM
tpd143
07-07-2015 09:06 AM
Suprarossa
07-06-2015 05:21 AM
