New leaf springs now steering rod hitting Ubolt?
Old Apr 21, 2013 | 09:26 AM
marmon77's Avatar
I replaced the leaf springs on my sons 85 4Runner, we went with 5" direct fit springs but when we put the Ubolts on and he went to turn the truck the steering rod hits the rear Ubolt and he can't turn the truck to the right. Why, with direct fit springs, is the steering now hitting? I wouldn't think the dynamics of thr steering would have been change. Am I missing something? My thoughts were to cut that one Ubolt in half and then weld it to the top part of the spring and then weld the bottom plate also so it wouldn't move. Your thoughts appreciated.
Old Apr 21, 2013 | 10:55 AM
85TurboRunner's Avatar
Can ya get a pic? The u-bolts are side by side, what do you mean rear u-bolt?
Old Apr 21, 2013 | 11:06 AM
marmon77's Avatar
On the front axle driverside one Ubolt is in front of the axle then the second one is behind the axle holding the leaf spring in place. When you turn the wheel to the right the steering arm moves towards the rear of the truck and hits the "rear" Ubolt or the one on the back sibe of the axle. If that makes more since?.
Old Apr 21, 2013 | 12:18 PM
4Crawler's Avatar
Either get the OME flattened u-bolts or switch to crossover steering:
- http://store.arbusa.com/Suspension-Systems-C16.aspx
Problem is your new springs are likely thicker than stock and that raises the u-bolts up to interfere with the steering drag link:
Other option is to remove a leaf from the spring pack to reduce its thickness.
Old Apr 21, 2013 | 12:34 PM
marmon77's Avatar
So does welding the ubolt to the spring sound like a crazy idea?
Old Apr 21, 2013 | 12:35 PM
marmon77's Avatar
What I meant was to cut the side that's hitting then welding the top part to the spring
Old Apr 21, 2013 | 12:50 PM
I don't think that would be a good idea.
Old Apr 21, 2013 | 01:06 PM
marmon77's Avatar
I looked at the link that 4Crawler posted but I'm really not to sure of what to look for. Could someone help me out here? Tell me what I need and all. Thanks
Old Apr 21, 2013 | 01:28 PM
You could always flip the ball on the J-arm. Would a drop drag link help?
Old Apr 21, 2013 | 01:53 PM
marmon77's Avatar
I'll have to check not too sure.
Old Apr 22, 2013 | 02:56 AM
91 4Runner's Avatar
Question: Were the springs that you replaced the original flat springs? If so, there is your problem - the original steering will not work with the stock push/pull steering. You will need either hi steer or a drop drag link for the 5" lift springs.
Pictures of the truck with its original springs and the new would really help!
Old Apr 22, 2013 | 03:25 AM
84foyota's Avatar
Ok I've experienced this as well. This due to the lift in the springs. It sharpens the angle on the drag link and causes interference on the u bolt.
Two posible fixes. 1 buy a new drop drag link - summit racing sells them and they are around $60. This is the route i took and it offers some other benefits as the new one is also adjustable so you can set the new centre position on the box too!. 2 have to ball cut off and rewelded on the top of the knuckle. This is a better fix in the end but make sure you get a really good welder as if this brakes you will loose all your steering. Made me nervous so i opted for the new link.
Old Apr 22, 2013 | 01:11 PM
rokblok's Avatar
Or just get a Hy-steer kit and tighten up the steering, make it safer and better for the beneficiary of the Toy...
Old Apr 22, 2013 | 01:17 PM
marmon77's Avatar
84foyota, I've been reading up on the drop limnk and moving the ball to the top. I just ordered the drop drag link and when it comes I will cut and re-weld J-arm back on are just punch the ball out and put it on top. Thanks for all your responses you'll have been a big help. My son will be happy also!!
Old Apr 22, 2013 | 04:35 PM
If you do end up modifying the J arm don't cut it just flip the ball. There are a few write ups on how to do it.
Old Apr 24, 2013 | 08:55 AM
marmon77's Avatar
I have another ? Can someone explain taking the drag link apart? Thanks
Old Apr 24, 2013 | 09:04 AM
4Crawler's Avatar
Usually there is a cotter pin that holds the end plugs secure. Then unscrew the end plugs:
- http://www.4crawler.com/4x4/4R_suspension.shtml#PhaseI
And take out the pieces, noting the stacking arrangement of the parts as you take them out. It has been over 15 years since I touched the stock drag link, the Factory Service Manual should have a servicing procedure. Dropped drag links are similar on the ends, although they tend to be symmetrical on both ends, with the spring loaded bits in the middle. The stock drag link is not the same on each end, one has the spring loaded bit on the end and the other end has the spring loaded bit in the middle as I recall.
Old Apr 24, 2013 | 09:19 AM
marmon77's Avatar
Thanks 4Crawler> I will be doing this when the drag link comes in.
88sasturbotoy
Jan 30, 2026 01:57 PM
shisha1999
Sep 21, 2015 08:22 PM
priest16
15
Aug 6, 2015 07:43 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
Nickdigg
Jul 7, 2015 06:04 AM
