- Window regulator question
- Duralast B945 radiator cap
- W56 Reverse Idle Gear, Now Available
- wiring up an electric fuel pump
- 1984 SR5 Extra cab 4wd drive shaft vibration
- Center console arm rest. I'm goin for it!!
- Carb question
- Seat padding/foam
- Please HELP my low beams quit working
- 'Lifting 22R' for axle clearance
- Mirror options question, 84 4runner
- 85 Pickup Tail Light Illuminating Reverse Reflector Mystery
- 1985 4x4 xtra cab short bed parking brake cable
- 85 turn signal problem
- Clutch issues
- Running lights, dash illumination, not working.
- 85 pickup diff bearing issue
- Brake swap question
- Dist cap ID issue
- brake lines
- Electrical problems! Click no start issue which needs assessment.
- Is this normal? 22RE
- Pickup lurch/jolt at 70mpg
- Can’t get the idle speed down!
- fuel lines from tank to bay
- Urgent need help!!! A.t. Oil temp, brake, and charge light!
- Bilstein 5100's for '85 Pickup
- 85 parking brake cable
- 2WD Wheel Options
- 4WD indicator light??? Transfer case wire
- 1985 W56 tranny 1 gear growl
- Gaskets for phenolic spacer under carburetor for 1985 22R
- What size vacuum tubing for 1985 22R Carburetor?
- Tow hitch for 1984 Toyoya 4runner
- Meet Roland the 'Headless Thompson Gunner"
- Looking for New or Rebuilt Carburetor Recommendations for 1985 22R
- Sloppy/loose steering
- Anyone know what this and is it worth saving I didn’t find a van forum
- 1985 22R Periodically Runs Great, Then Horrible (If at all)
- Back up Lights
- knuckle shimming
- Fuel lines
- Cam and crank timing assistance 22r
- 1984 SR5 Extra cab, need a part.
- Mysterious Oil Loss
- bought a 20r 22r hybrid
- looking for production numbers
- brake booster operation in question
- Exhaust Ring?
- 22re Power loss, CEL 12
- Speedometer Cable
- My 1985 pickup died several times on the highway and now won't start.
- 1985 Pickup Parking brake having a hard time administering brake
- 1984 Pickup Rear Axle / Third Member For Sale
- Stripped Lower Manifold Threads
- To Much fuel non-start issue
- Vin and IFS mistery
- valve body separator plate
- Fuel sender 0-90?
- Anyone know what this is? Is it a starter relay?
- What is this and should something be attached to the tip?
- Stereo Bracket Dimensions
- Issues Starting
- Front wheels wobble
- How rare is this graphic/decal?
- 85 22R Auto choke not working
- Survived hitting a wall at 60mph. Pics Included, now front axle is crooked.
- Insurance Suggestions for Daily Driven Restored 1st Gens
- A.T. Oil Temp, Charge, and Brake light come on every once in a while when driving.
- Brake calipers help
- '89 22r into '84 2wd pickup
- Unknown soft top frame?
- Looking for info on an 85 Diesel truck
- automatic transmission shift cable needed
- Identifying Engine Noise
- Sliding back window 84 85 regular cab
- carb id
- Cylinder Head Reccomendations
- Hitch receiver for gen5 pickup?
- Rough Cold Idle
- 1984 pickup wiring
- CSF 2314 on an 85 Pickup?
- OEM Radiators - What do the letters mean?
- 84 Pickup Map Dome Light / Rear View Mirror Swap
- Blowing the dust off old Lucy, need help!
- How to fill transmission chain link
- 85 pickup engine swap-or sell
- 1985 Toyota Truck electrical issues
- Major electrical issues with 84 22r pickup
- Third condenser? What is this?
- Clean or replace Transmission filter
- Engine bay wiring mess.. plz help!!
- 1985 Toyota Pickup Vacuum Leak
- Which Transfer Case is Stronger, Gear Drive or Chain Drive?
- Power and Manual steering box mount.
- Suspension too stiff
- Aftermarket Coolant Temp Gauge Install
- 1985 Battery Support Tray
- need vsv
- 1985 Pickup 2LT blew a hole in the cylinder block
- Wiper upgrade
- Stolen Runner??
- Can you identify this rubber dash part
- 1985 Toyota 1-Ton Front Brake Hoses & Fittings
- Bomb proof motor mounts
- RN65 frame found, what would you do with it?
- Air conditioning charging
- Evaporator noise/whistle in new A/C. Help!
- CRANK, but No Start 22RR
- Can 22250-35050 substitute for 22250-35020?
- Cruising around 50mph at 220F To Hot?!?
- Sunroof, air deflector hinges.
- 1985 toyota turbo diesel
- Help with (manual) steering gear rebuild kit
- How often do you adjust your valves?
- Wiring Harness Grommet
- 1985 4x4 pickup front leaf springs
- 84-85 truck 134a freon capacity
- Fuel level sensor shenanigans
- Replacement Speakers for Stock Dash?
- Long Distance Rough Idle/Check Engine
- Need help with my 85 4Runner
- 22re connector help
- Manual Transmission swap ?
- swap 92 buckets into 85 bench
- 4x4 ride improvement
- 1985 Toyota pickup splice for trailer
- replacement alternator needed
- Does back wall trim exist??
- First introduction to this forum
- 84 pickup cuts out and backfire
- Replace Bucket seats
- new stock front springs for LCE look wrong
- Need help identifying a noise
- Need some help, no accessory power.
- might need a rebuilt automatic transmission
- any low buck hood strut kit options
- 22re rod bearing question
- loose shifter on automatic
- 2" lift front shackles ?
- Replacement for this connector (idler valve)? 1987 4Runner
- replacement truck bed wheel tubs wanted
- Radiator and Electric Fan Set Up
- no power to interior lights and cargo light
- Shock bushing sizes and aftermarket recommendations?
- firm power steering normal
- Swapping 40 amp LEF alternator to 55 amp FEN
- Slack in throttle cable
- trail gear rear bumper
- Can't find a part, please help
- Popped a relay next check engine reader on my 85?
- Battery not charging
- retrofitting ac out of a 2003 lexus is300
- 1985 22R Aftermarket Igniter (that works below 40 deg. F)
- Removing Speedo needle?
- 22r gutting smog pump to use as pulley only
- Parts Sources Master List
- Quarter vent window to full glass conversion
- Window down! Window down!
- Head Gasket for turbo'd 2L-I
- Stumped by mysterious clutch issue
- High Idle issues
- 2wd lift with cranking torsion bars, how will the suspension be affected?
- Pulled axle to see if it is a Longfield
- OEM parts from PartSouq.com reviews?
- Timing Chain Kits 22R
- Having a car is great.
- High RPMs after HG replacement
- Roland’s annoying electrical issue
- Doubler help
- 260 cam and igniting timing question.
- Pinion angle help
- 85 Toyota Pickup 22R fuel pump line diagram
- 2WD Manual Steering Box loves doing FLIPS! But I don't...
- Rough idle when engines warm
- Need Header/Exhaust system for 1UZ conversion
- How to make a 22RE NOT run?
- Loose connections after HG replacement
- Go Rhino Charger 2 RC2 Bull Bar
- Powerless dead zone when accelerating, cold.
- Are there any locking tailgate latches?
- Wheel weight orientation?
- Rock sliders
- 86 Rear Bumper Fab
- Non Power Steering Conversion?!
- Aftermarket radio, factory anti theft?
- Welding hitch receiver tube to steel bumper?
- Master cylinder choices
- Sacramento Mechanic Recommendation
- Camshaft won't turn after torquing head bolts
- Engine backfires/sputters under load
- 85’ 4Runner hub issue update….
- 22R Carb Outer Vent Control Valve
- 85 4Runner hub issue.
- 1988 Pickup Spare Tire Kit (Stolen)
- Re-jetting for Headers?
- Would faulty front drive shaft cause vibration in 2wd??
- Schematics
- 22re vacuum help
- Manual Steer Gearbox for 4wd pickup?
- 1989 TOYOTA gas tank DOLPHIN QUESTIONS
- Passenger seat
- Windshield Sun Shade for 1989 Pickup?
- Drum Brake Self Adjusters
- slow shift automatic
- Another Weber 32/36 question…
- 85 4Runner 22RE MT Starts then Dies
- ignition switch wire harness connector
- REBUILT 1985 Toyota pickup 22R running real bad
- Mystery whit piece under door trim panel?
- 80 amp fusible link module
- 1985 Toyota 4x4 truck won't start...
- 22r crankshaft from ebay
- W i w trailer
- how to determine
- 1985 Manual to Power Window with Vent
- 85 22re no start
- Stripped Water Pump Bolts! New timing chain and cover?
- California emission test on 85 truck (carb) question
- 1.5" wheel spacers do not fit locking hubs
- New fuel pump, need to prime?
- Help me 22re ppl
- CEL Throwing different codes
- W56 5th Gear whine
- Fuel Pump Arm Fell Off Cam and Clicking
- Engine Shaking Rough Idle SOLVED... mostly
- Cruise Control
- Desperate for air intake duct #17880-89103
- 88 4 Runner Disappointed
- 1985 carb info
- Hole drilled in muffler?
- '84 22R, hard start, rough idle, dies when throttle applied
- 85 Pickup - Where does this reverse harness mount?
- 85 temporary no start troubleshoot
- My First Truck! Intro and Aftermarket Bolt Question
- 84 4runner - Slowest Build Ever
- 85 Yota 4x trans issues.
- 1988 4runner smog fail
- 85 22r burning LOTS of oil but good compression
- 1985 4x4 Truck Combination switch
- 22rte injector no fire and fuel pump not turning on
- 1985 1986 1 ton replacement front bumper need
- Rear Axle half shaft Dimensions
- Need help removing engine fuse box
- 22R temp gauge not working question
- Transmission ID
- Paint options for 85 wheeler/driver
- Which Calipers And Rotors Are These? IFS Hubs?
- Weird brake problems
