Transmission ID
Old Feb 25, 2023 | 05:56 PM
DISN102 YOTA's Avatar
Transmission ID
Hafa Adai (hello),
newbie here, but need advice from any and all my YOTA experts! I have an 84 YOTA, 2wd, 22r Carb, and 5 speed trans. The tag in my engine bay states YOTA is supposed to be equipped w/W42 which is a 4speed. Obviously the trans was swapped out!
question: where on the trans or what way or how to identify what trans I got? In advance, I appreciate all and any advice given!
Old Mar 6, 2023 | 05:57 AM
13Swords's Avatar
5 Year Member
I'm not great on this but here's what I have. My best guess is that it's either a W50 or a W56. I'd think more that it's a W56. You can check the transmission for an ID number to get some idea of it. Here's how it breaks down:
This will at least give you some idea of the date it was made. Here's the rest of the info from the site I got that from: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/http://tcase.rsgear.com/articles/2001_06.pdf
Wiki also has some info here: https://en.wikipedia.org/wiki/Toyota_W_transmission#W40
And there is Marlin Crawler. If there is anything to know about Toyota transmissions for 4runners & trucks they would know: https://www.marlincrawler.com/transmission
Old Mar 6, 2023 | 01:05 PM
thank you, I will definitely look into this. Also I forgot to mention, my speedometer don’t work and when I went to check why - connection on passenger side of transmission is for sensor and not cable. Idk if this can help for ID’ing the transmission as well! Appreciate your help!
Old Mar 7, 2023 | 08:04 AM
13Swords's Avatar
5 Year Member
From what I can tell from parts listings, it looks like Toyota switched from a speedo cable to a speed sensor for 1985 & newer pickups.
Old Mar 7, 2023 | 08:14 AM
mechkw's Avatar
If it is a 2wd 5 speed, it should be a w55. Don't know of any 4 speeds after 1982 or3. The 4 speeds were an L designation as far as I know
Old Mar 7, 2023 | 05:17 PM
with what you stated, I should be able to switch my gauge cluster that will take an electronic sensor and connect to trans right? From an 85 and newer pickup!
Old Mar 7, 2023 | 05:23 PM
I have a coworker with a 90, 2wd, efi, with a 4 speed trans! However possibly got swapped out, who knows?!
2003mikem
Nov 4, 2011 10:12 AM
808 4 runner
Mar 8, 2011 05:09 PM
hunter07
Aug 15, 2009 07:31 AM
SHANEMAN
Apr 20, 2004 01:13 PM
