newbie here, but need advice from any and all my YOTA experts! I have an 84 YOTA, 2wd, 22r Carb, and 5 speed trans. The tag in my engine bay states YOTA is supposed to be equipped w/W42 which is a 4speed. Obviously the trans was swapped out!
question: where on the trans or what way or how to identify what trans I got? In advance, I appreciate all and any advice given!
I'm not great on this but here's what I have. My best guess is that it's either a W50 or a W56. I'd think more that it's a W56. You can check the transmission for an ID number to get some idea of it. Here's how it breaks down:
This will at least give you some idea of the date it was made. Here's the rest of the info from the site I got that from: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/http://tcase.rsgear.com/articles/2001_06.pdf
thank you, I will definitely look into this. Also I forgot to mention, my speedometer don’t work and when I went to check why - connection on passenger side of transmission is for sensor and not cable. Idk if this can help for ID’ing the transmission as well! Appreciate your help!
From what I can tell from parts listings, it looks like Toyota switched from a speedo cable to a speed sensor for 1985 & newer pickups.
with what you stated, I should be able to switch my gauge cluster that will take an electronic sensor and connect to trans right? From an 85 and newer pickup!
