fuel lines from tank to bay
I am having trouble mounting fuel lines on my truck. I recently installed the cab and fuel tank but I did not keep track of what fuel lines go where when I removed them. (had it bare frame at one point)
the frame is an 85' 4x4 short bed and both the fuel tank and the cab is off of an 87' 2wd long bed. I removed the fuel lines to start the project and now I am unsure of where they go. I remember that one of them ran with the proportioning valve brake lines, at least on the 2wd frame but I have trouble mounting it as it doesn't seem to fit. but I also need to run two more lines.
does anyone on here have a diagram or a picture of what lines go where? is there any more details I need to include? I can take pictures if that helps. I'm really just looking for a diagram. or a page in the factory service manual.
thank you
thank you
I figured out where two of the lines run by looking at the 4wd cab that hasn't been totally stripped yet. they don't go all the way to the tank so I started at the firewall. I know there are shorter lines plus rubber lines that make it the rest of the way. the lines that I'm using for example aren't identical between 4wd cab (22re) and 2wd cab (22r) but I was able to look at the firewall mounts and get them where they need to be.
any tips are appreciated as I just have the remaining fuel lines layed out and I'm not totally sure where they go. I'm going to use an electrical fuel pump that I plan on mounting where the fuel filter was mounted if that helps.
Factory service manuals can be downloaded from this link...
https://web.archive.org/web/20110102...ttora.com/FSM/
Here's a link to the fuel line parts diagram for my '87 2WD long bed.
https://japan-parts.eu/toyota/us/198...el-tank-tube/2
stephenb123
Feb 28, 2022 07:18 PM
