PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31
  1. my dream
  2. New engine - no oil pressure
  3. Newbie with Transmission ID ?'s
  4. 85 yota pickup e brake cable removal?
  5. so here's the deal...
  6. 1985 4runner found!!!
  7. pickup or 4runner
  8. checking out an '85 4runner, input needed
  9. in need of new lift kit help me out
  10. performance cam
  11. thug
  12. Sr5 Dash Install Issues
  13. 85 22r reg cab 5spd or 85 xcab 22re Auto
  14. New guy: $100 '85 Pick-Up
  15. 85 4runner FSM
  16. Putting my knuckles back together (quick question)
  17. Intro, crossover, OME and sway bars
  18. 85 4runner suspension
  19. How to adjust the throttle plate
  20. 85 yota pickup cage in cab
  21. Carburetor shaft bushing?
  22. My Project Truck is Finally Here!!
  23. What filter is that?
  24. guaging interest in my truck, detroit area
  25. How Does yalls look so much higher
  26. 85 Pickup Body Lift
  27. rear springs
  28. why not body lift
  29. Dash removal (ac controls)
  30. 1st gen Runner factory front spring length
  31. Just Bought a 84PU, Got $3k, What Can I Do?
  32. 39.5 iroks?
  33. Custom CB and iPod Console, with Shifter boot upgrade.
  34. what lift for my 85 4runner
  35. Interchangable seats???
  36. Problem with rear brake locking up on 84 pickup
  37. Rear wheel cylinder on 10/85 build date
  38. Proud owner of an 85" 4runner SR5......
  39. 84 22re overheating
  40. so i got a death wobble?
  41. What would yall pay for these two 84 PU's?
  42. Most rusted SFA in a daily driver ever?
  43. a/t or t-case problem.
  44. NO power whatsoever
  45. 85 pickup carb or EFI ?
  46. Tranny model number?
  47. 22re intake manifold removal
  48. Big trouble, cracked hub body, can I buy parts anywhere, or just whole replacement?
  49. jonney or heim???
  50. conversions
  51. 3" Rear Lift Springs / 84 4Runner
  52. 91 PU 2wd axle on 85 4runner swap...
  53. tire size question
  54. 85 4runner to Truggy @ ORS
  55. convertible 4 runner
  56. Downey Exhaust system
  57. 84 motorpic request
  58. electrical problems
  59. Assisstance Request: 1st gen Runner and Tape measure - inquire within.
  60. let me know
  61. Help - need a photo of an engine compartment
  62. Lift spring question
  63. my tires go \ / then / \
  64. Value $ 1985 4runner SR5?
  65. quick question
  66. no oil in the oil filter
  67. MPG for stocker 1st gen runner?
  68. A304H Tranny Questions
  69. Sale truck found in Fl.
  70. Storing 85 4Runner
  71. 5 spd Tranny?
  72. Birfield Joint
  73. Valve cover removal
  74. clunking noise
  75. I Have An 85 Efi 4runner How Do I
  76. Odd Vibe??
  77. engine rebuild parts?
  78. Truck hunt!
  79. Front Tow hook bolt specs?
  80. big brake problem
  81. 85 wiring harness question
  82. Power Steering Conversion 1980 to 1985
  83. What can I get for my 4Runner?
  84. 85 tach
  85. Phenolic carb spacer
  86. new found problems...
  87. water pump replacment
  88. Rear Main Oil Seal
  89. Re-Gearing Front Axle, What does it take to remove the Front Dif?
  90. 22RE Squealing V-Belt/Pulley Problem
  91. 3 Q's
  92. Hi all, new 85 4runner project - I need advice!
  93. a few little questions
  94. jmazos's 84 pickup buildup.
  95. need some advice on clearin 35s. please
  96. starter solenoid wire?
  97. Whats a better engine swap header, Advanced Adapter or NWOR?
  98. 4 Inch Drop Drag Link Spare Parts
  99. 84 bad tranny???
  100. what the heck is this
  101. Me and my weber 38
  102. Spare Rim
  103. whats an 84 worth?
  104. what weber carb to use?
  105. body damage
  106. 22RE timing at 5,000ft?
  107. My '85 4Runner build
  108. replacing motor mounts....?
  109. A "little" carbon build up
  110. Buysell Article
  111. WTH is Wrong with my 85 22rE ??????
  112. Auto to manual hubs on 85
  113. TeraFlex Shackles for 84Runner
  114. Is it just me or
  115. Frame Rust Options?
  116. Anybody have a 4" Marlin lift and 35's?
  117. Is This Possible?
  118. bracket question
  119. Semi Beadlock 15's
  120. Difference between 84 22r and 85 22r?
  121. auto trans flush
  122. cam gear / chain ???
  123. 1984 toyota 2wd oil pan!!
  124. 85 pickup won't crank [noob thread]
  125. My new rim and tire package!!
  126. Wife is making me sell the 85 Part -2
  127. seat question
  128. Differences in '84-'85 22r engines
  129. Aftermarket EFI
  130. Brake light coming on when I puch the clutch in.....
  131. 85 longbed questions
  132. transfer shifter problem
  133. Knuckle rebuild help.
  134. 4 door 85 toyta pickup
  135. 86 4runner 22re Altinator upgrade
  136. i have an 85 efi 4runner tcase question
  137. 3/4 fit on 1/2 ton?
  138. Adjusting Booster Push Rod
  139. free repair manuals
  140. 1984 22r truck timing change help!
  141. Frnt Diff took way more oil then specified
  142. 85 4rnr Rear seat cover plate?
  143. push rod too long?
  144. My Project 4runner, What should I do?
  145. booster
  146. Best Website for yota parts?
  147. Catastrophic carnage
  148. Right hub staying Locked!!!
  149. Wife is making me sell my 85 what would be a good price?
  150. 4runner soft top
  151. where does this spring go?
  152. Another winch discussion
  153. MPGs after Modifications
  154. help identifying harness plug (pics)
  155. 1994 4runner auto transmission
  156. Have A Problem, Need Help.
  157. I have a question
  158. Replacing Oil Pump
  159. My heater died the other day and it's cold
  160. PCV Valve and more!
  161. lower control arm
  162. propane conversion??
  163. Stupid Lighting Question.
  164. Anyone in here living in WVa?
  165. My Yota is not starting, help!!!!!!
  166. good header for 22r
  167. High performance 22r
  168. 87 body on 84 frame
  169. possible vaccum leak
  170. 85 runner Clutch noise?
  171. pace setter header?
  172. what should i offer
  173. Alternator Upgrade, But Need Help
  174. Knuckle arm replacement?
  175. 4 wheel indicator light
  176. High Output Alternator
  177. YT'ers of the 84-85 trucks HELP!
  178. 1985 std cab pickup camper shell?
  179. Good tire size for stock 22re?
  180. 22r what is a good quality radiator?
  181. yet another weber question
  182. Fiberglass fenders?
  183. What to look out for in an 84 4runner?
  184. Fitting Tacoma front bumper on 1st gen?
  185. ** YET another tire/wheel question! 3rd gen wheels on 85 4runner
  186. Crankshaft Pulley Bolt
  187. Bud Built Skid Plate HELP!
  188. update on my 84
  189. Need help with wheels, wont fit... were suppose to.
  190. your ride
  191. break lines
  192. Bad Noises from each side of Axle housing?
  193. 85 starting issue
  194. need exploded view for Warn Hubs
  195. Shock Question! Help Needed ASAP.
  196. wheel/tire fitment
  197. Different types of Engines, pros and cons
  198. Removing rear window key cylinder?
  199. sputtering 85 22r
  200. new truck....
  201. Oil leak on 22re
  202. Dr.Trevorkian's 1984 4Runner Build-Up Thread
  203. re-gearing
  204. noise from transmission
  205. power steering pump interchangeability?
  206. Diesel in gas tank
  207. Would these 08 Tundra wheels/tires fit on my 85 runner?
  208. 92 4Runner Buckets
  209. running hot
  210. Driveshaft ?
  211. What is this Sensor
  212. Inclanometer Question
  213. Removing rear shackles (85 4runner)...
  214. Need a cab.for a rolled 85runner
  215. Turn signals, fuel gauge, and several idiot lights all quit at once on me
  216. Clutch Upgrade?
  217. 85 cutting out
  218. WHAT THE bell!
  219. Crashed my mint 4runner...now the blinker doesn't work.
  220. backfire from the air box???
  221. Chevy motor swap.
  222. 85 4runner starting prob
  223. Miss at idle?
  224. Engine upgrades
  225. 84 Simple lift
  226. Ride Quality?
  227. Custom cener console build
  228. 85 4runner tranny sticking?????
  229. u bolt question...
  230. Rear main seal
  231. 1985 SR5 tranny problem.
  232. shackles
  233. Fule problem on 84.4x4.22r, need help?
  234. Auto-Manual Swap Question
  235. 22RE Overheating
  236. Rear Cargo Door Not Opening
  237. oem cruise install
  238. Clutch Problems
  239. new hg 3 days ago and still steam
  240. saggy springs on an 84 pickup
  241. Pics Of stock solid axle setup
  242. how do you pull codes
  243. 84 4runner
  244. SR5 Options
  245. 22re head seal
  246. timing chain cover question
  247. 22r Timing Chain Maze
  248. whats the leak?
  249. charging problem...
  250. Where is R&R speedo cable in factory manual?
