Inclanometer Question
Old Dec 31, 2007 | 12:40 PM
myyota's Avatar
I just ordered an inclanometer from yota yard for my 84 4Runner, i asked then to include the mounting hardware and wiring, they said the wiring needed was already in the dash. Ive had my dash out to replace the heater core and didn`t notice any wiring or plugs that would be for the inclanometer, so were or how does it plug in ?.
Old Dec 31, 2007 | 12:44 PM
RobD's Avatar
The only wiring you should require for your inclinometer is one for the light. The inclinometer has no power needs, aside from that. If a wire isn't readily available, you should be able to tap into one that runs to your heater panel backlighting.
Old Dec 31, 2007 | 01:07 PM
myyota's Avatar
Yea, thats what i was talking about, i wasn`t sure how the lights hooked up.
Old Dec 31, 2007 | 01:47 PM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri...l#Installation
Old Dec 31, 2007 | 01:57 PM
Dublin's Avatar
If it came with the full inclinometer harness it will have male and female ends. They just daisy chain into the climate control back lighting.
Old Dec 31, 2007 | 02:04 PM
apalmer1's Avatar
Yea if you cant find wiring for it all you need is to tap into one of the many 12V sources that are wired in circuit with the backlights. The actuall inclinometer is just a series of balances and levels with needles on them.
Old Dec 31, 2007 | 02:20 PM
881stGenRunner's Avatar
when you get your dash pad off, flip it over and notice the 4 holes that are already there to be punched out. Dont attempt to make your own holes, they are alread there.
lectric80
Aug 11, 2015 12:02 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
