Inclanometer Question
I just ordered an inclanometer from yota yard for my 84 4Runner, i asked then to include the mounting hardware and wiring, they said the wiring needed was already in the dash. Ive had my dash out to replace the heater core and didn`t notice any wiring or plugs that would be for the inclanometer, so were or how does it plug in ?.
The only wiring you should require for your inclinometer is one for the light. The inclinometer has no power needs, aside from that. If a wire isn't readily available, you should be able to tap into one that runs to your heater panel backlighting.
Yea if you cant find wiring for it all you need is to tap into one of the many 12V sources that are wired in circuit with the backlights. The actuall inclinometer is just a series of balances and levels with needles on them.
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
