timing chain cover question
Old Dec 11, 2007 | 01:45 PM
Cumminspwr's Avatar
hey i was wondering if you have a 22re bare block and have a 22r head/ timing chain cover will it bolt onto the 22re block or are they different sizes?
Old Dec 11, 2007 | 01:56 PM
4Crawler's Avatar
If they are both '85 or later then all should fit. The pre-85 blocks were shorter than the later ones, so I would imagine the timing chain cover would be shorter as well.
Old Nov 19, 2008 | 07:31 PM
yota lover's Avatar
yea they should fit if they are in the same year groups, when i did my rebuild there was several parts that would fit on the 22r and 22re.
Old Nov 19, 2008 | 07:53 PM
drew303's Avatar
x2
The heads are same for 22r/e as well. Regardless if it has the oval or pear shaped exhaust ports
Old Nov 19, 2008 | 08:02 PM
DeathCougar's Avatar
Originally Posted by drew303
x2
Thats not true, the oval shaped exhaust heads have a center mount exhaust stud and are the 81-84 style. The "pear" or "lightbulb" style is 85-95 only. The two can't be interchanged without some sort of modification to at least the exhaust and intake (which bolt on different as well)
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
