water pump replacment
Old Feb 18, 2008 | 06:00 PM
meap's Avatar
Went to my mechanic today for my inspection and he said that my water pump needs to be replaced. He also said that I need a new slave cylinder becuase it's leaking and valve cover gasket. So he's going to do the following for about $490.
water pump
coolant flush
thermostat
valve cover gasket
slave cylinder
belt
What do you guys think? I'm thinking I can do the water pump myself.
Old Feb 18, 2008 | 06:24 PM
stabmasta's Avatar
Download a FSM and save $400.00 by doing it yourself.
Old Feb 18, 2008 | 07:01 PM
DeathCougar's Avatar
NOt really a bad price for all the parts and labor on that.
But if you are mechanically inclined, i would do it yourself. Its all easy stuff, the hardest part is draining and removing the radiator, and all the belts etc to do the water pump.
However, shops often have equipment far superior to what Joe Blow has for flushing a system. Sorta 6 of one, half dozen of another.
Old Feb 18, 2008 | 07:15 PM
myyota's Avatar
You can buy all the parts for about 170 dollars, and if you can do it your self you can save about 300 dollars. like said above, its all easy stuff to do and you could have it all done in one day.
Old Feb 19, 2008 | 07:31 AM
eric-the-red's Avatar
If you're doing the slave cylinder I would do the clutch master cylinder as well, especially if it's still original. Proabbaly would add $50-75 to the price but it always seems when you only do one cylinder on the clutch system the other one goes soon after.
And if you think you can do the water pump yourself then the other stuff should be even easier.
Old Feb 19, 2008 | 07:37 AM
Aywilkerson's Avatar
I was an F/18 mechanic and found that it was easier to work on than removing the water pump, the belts, fan, timing belt which should be replaced, and timing belt tensioner, it became a a bigger job than what I thought I could do, I paid 450 for my to get replaced and I brought them the parts. your getting a deal. in my opinion. Oh and if you do decide to do the job your self, read read read about it. and make sure that you have metric tools.
Old Feb 19, 2008 | 09:49 AM
88wildrunner's Avatar
that stuff is easy, i just replaced my water pump and belts yesturday, the only hard part was scraping the old gasket off, becuase of the odd position and gettting the fan on and off can be a bitch unless you have small hands.
Old Feb 19, 2008 | 04:32 PM
meap's Avatar
Download FSM? What do you mean?
Also, where do you guys recommend getting the parts? I looked on engnbdr for the water pump, and maybe I'm retarded but I couldn't find anything on a water pump part.
Yeah, by the way, he said there was no need to do the timing chain. I have 116K miles and he said the timing chains usually last a long time. I mentioned about the plastic guides and he said if they start to go you'll hear a change in the sound of the engine when it's running.
Old Feb 19, 2008 | 04:58 PM
i got my parts at reibies, which sells all napa parts, or you could go to toyota but youll pay more.
about $90 for water pump, all belts and thermostat.
Old Feb 19, 2008 | 05:30 PM
85TrailRunner's Avatar
FSM = Factory Service Manual.....its available for download, check out the link below to download it.
http://www.mediafire.com/?1gwedrajyv3
Old Feb 19, 2008 | 06:38 PM
Trustyrusty's Avatar
So I changed my water pump for 30$... I bought the pump, at autozone, and changed it, stop being a wussy and DIY. Oh and 490$ is a total ripoff, you could prolly do everything you said for like under 300$ EASY.
Old Feb 19, 2008 | 09:42 PM
$300 is high for all those parts, at the most id say it would be around $150 for all the parts, plus if you do it yourself, you'll know how to replace those parts in the future. since im sure your gona have to replace the belts, thermostat and posibly the water pump again.
Old Feb 21, 2008 | 04:22 PM
meap's Avatar
Thanks for the FSM link! I didn;t kow that existed.
I plan on doing it myself. I'll wait for a warmer day.
Thanks for the comments
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
