Replacing Oil Pump
Old Jan 21, 2008 | 05:31 PM
myyota's Avatar
Replacing Oil Pump
Im going to be replacing the timing chain and guides on my 84 4Runner, and while everything is a part im also replacing the water pump and oil pump, when i replace the oil pump is it just a matter of unbolting the old pump and bolting on the new oil pump ?, does anything else need to be done ?. the reason im replacing the oil pump is because it has 240,000 miles on it and while everything is a part it would be a good time to do it.
Old Jan 21, 2008 | 06:36 PM
toytech76's Avatar
if you are gonna replace the oil pump, pack it full of clean wheel bearing grease inside. It helps prime the pump so you dont have a elongated dry start or no suction at all
Old Jan 22, 2008 | 05:56 AM
myyota's Avatar
So do i just put the grease in between the gears and then bolt the oil pump on ?.
Old Jan 22, 2008 | 11:44 AM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
Wtf? Grease?? Are you serious?? Ive never heard of that. I definetly would not want grease floating around in my engine. If youre worried about a dry start, which really isnt that bad. I would use a heavy weight OIL to pre lube it. Other wise, I would just bolt it on, thats what I di anyways. Works fine.
Old Jan 22, 2008 | 12:05 PM
tampabayota's Avatar
use vaseline it is what everyone here uses
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
