5 spd Tranny?
Old Feb 25, 2008 | 03:58 PM
mdelros's Avatar
5 spd Tranny?
Do you boys know if an 85 4runner and an 87 4runner have the same 5spd tranny? they are both SR5 if that hepls
Old Feb 25, 2008 | 08:27 PM
fillsrunner4's Avatar
This site should help answere your question
Marlin Cralwer
Old Feb 25, 2008 | 11:20 PM
Wardamneagle's Avatar
Yes. Same 5 speed transmission. FWIW, SR5 or Deluxe, they still have the same transmission.
Old Feb 26, 2008 | 03:12 AM
85TurboRunner's Avatar
As long as they are both EFI then they have similar trannys. The 85 will have a W-56A and the 87 will have a W-56B, the difference being the part that connects the tranny halves together. On the A it is steel and the B is aluminum.
Old Feb 26, 2008 | 03:22 AM
All 4Runners were EFI except for 1984 (the first year).
Old Feb 27, 2008 | 11:03 AM
klr toy's Avatar
Don't be so sure about that! There are a few out there that were carbed. You could get carbs in Canada right up to the early 90's on 22r's and they do have different trannies. As long as both of them are EFI, they will be a direct swap. If you get a trans/case from a carbed truck, both of the shift levers will be in the trans housing with a block off cover on the t-case. The EFI will only have one in the trans and one in the t-case. This is the easiest way to tell if it's already out of the truck just at a glance.
Old Mar 2, 2008 | 10:33 PM
RandyatBBY's Avatar
So is there a diferance in the name or codeing?
Old Mar 3, 2008 | 06:20 AM
4Crawler's Avatar
Marlin's page has a good description of the various transmissions used in the various vehicles:
http://www.marlincrawler.com/htm/tra...ansmission.htm
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
