85 tach
Old Feb 21, 2008 | 05:03 PM
j's85's Avatar
85 tach
I just bought a tachometer for my 85 truck. the package says that i need to connect a wire to the ignition coil, but the truck doesn't have one. any ideas on where to connect it?
thanks josh
Old Feb 21, 2008 | 05:18 PM
ozziesironmanoffroad's Avatar
its got one, or else it wouldnt start
Old Feb 21, 2008 | 05:51 PM
j's85's Avatar
well it has an igniter but i didnt see a ignition coil.
Old Feb 21, 2008 | 07:19 PM
myyota's Avatar
The coil is mounted on top of the igniter, just follow the coil wire (middle wire) on the distributor back to the coil.
Old Feb 21, 2008 | 07:20 PM
drew303's Avatar
There should be a green plug coming off the coil
It's a single wire w/ a single green plug. Just hook into that. It's really easy.
Old Feb 21, 2008 | 08:10 PM
j's85's Avatar
I found the wire coming out of the coil with the green plug. I spliced into that wire but the tach still won't work. The needle starts out straight down, then goes right to the 8 and rests there. When I rev the engine the needle goes counter clockwise from the 8 back up to the 4 or 5. Do I hvae something backwards?
Old Feb 22, 2008 | 10:14 AM
deserttoy84's Avatar
how many threads are you gonna start about this tach?? YOu most likely have a bad tach... my friend went through 2-3 sunpro tachs before getting one that acutaly worked
Old Feb 22, 2008 | 11:18 AM
sh0kk86's Avatar
did you make sure the switch on the bacck is set to 4cyl and not v6 or 8
Old Feb 23, 2008 | 06:39 AM
j's85's Avatar
Sorry about all the threads, i just couldnt figure it out. but yes the switch is on 4, i guess it is just bad.
Old Jul 20, 2010 | 06:25 PM
twhite's Avatar
I have a 85 runner that was converted to carb. I have an ignitor out of an 83 pickup and I am trying to use the stock SR5 tach. Does anyone know what wire to connect the ignitor wire to. I have checked the wiring diagram and traced what I thought to be the tach wire in the factory harness from the cluster to under the hood. It still does not work.
shisha1999
Mar 3, 2016 07:09 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
imhousing
Sep 10, 2015 02:04 PM
O Holy P
Aug 18, 2015 02:33 PM
