big brake problem
Old Feb 23, 2008 | 01:22 PM
yota925's Avatar
big brake problem
I swapped my calipers with v6 units and ceramic pads. I aslo put in a new master cylinder from fj80 1 inch bore. Now my pedal is hard as hell to push down and won't fully stop my vehicle. I've checked for vacuum leaks with no luck. The brakes worked fine before the swap just a little weak so I don't think it's the booster either. I'm stumped and out of money.
Old Feb 23, 2008 | 01:23 PM
yota925's Avatar
i'm not sure where to start looking because everything is new and not leaking.
Old Feb 23, 2008 | 01:24 PM
toytech76's Avatar
did you check your push rod adj?
Old Feb 23, 2008 | 01:28 PM
yota925's Avatar
how do I check that. I haven't touched it since replacing the mc.
Old Feb 23, 2008 | 01:33 PM
yota925's Avatar
if it's hard to push the pedal would it need to be adjusted forward or backward.
Old Feb 23, 2008 | 01:34 PM
toytech76's Avatar
under your dash, there is an adjustable push rod that goes into the booster. Loosen the jam nut and adj the rod as needed. I forget how much but there is a certain amount of play that needs to be in the pedal
toytech76's Avatar
you dont want too much play but you dont want it tight either
Old Feb 23, 2008 | 01:42 PM
SEAIRESCUE's Avatar
Go to the parts store and get the MC for a V6, preferably same year as your V6 brake parts. You have a mismatch and the MC bore is too small. I think the V6 has a 1 1/4 inch bore. And, read the MC install instructions that come with it to make sure the push rod is not holding pressure in the MC, etc.. Return the ceramic pads and get OEM metallic and turn your rotors.
Old Feb 23, 2008 | 02:26 PM
yota925's Avatar
i adjusted the push rod and it did help but the brake pedal is still hard and it doesn't stop like it should. if i try to lock up the brakes on gravel they only lock up when the pedal is mashed to the floor and then it's still weak.
Old Feb 23, 2008 | 02:29 PM
toytech76's Avatar
I agree with seaire, get the correct master cyl and adj the pushrod. Also make sure your entire brake sys is bled thoroughly.
Old Feb 23, 2008 | 02:30 PM
rowdy235's Avatar
Is this like the MC you have?
http://www.marlincrawler.com/htm/brakes/mcylinder.htm
If so, Marlin Crawler says it will work.
I think you got a bad MC.
Old Feb 23, 2008 | 02:33 PM
yota925's Avatar
i got the mc from trail gear and they told me with my upgrades to my brakes this was the correct one. if i get an mc from the parts store for this year of brakes will i be able to tell the difference between my 85 stock rotors and calipers and my new 92 calipers and vented rotors. all i'm trying to do is increase my braking power. future plans also include rear discs.
Old Feb 23, 2008 | 02:35 PM
yota925's Avatar
mine looks identical as that one part # and everything
Old Feb 23, 2008 | 02:41 PM
rowdy235's Avatar
then I think you got a bad MC, I'd exchange it
Old Feb 23, 2008 | 02:50 PM
yota925's Avatar
thanks for the help guys. its hard to find anyone who will respond.
Old Feb 23, 2008 | 03:24 PM
redyotarunner's Avatar
Did you bench bleed the MC before installing it?
Old Feb 23, 2008 | 09:09 PM
yota925's Avatar
i did bench bleed it. when i bench bled i couldn't get rid of the bubbles. maybe i didn't do it long enough. i push the piston in about 10-15 times. wouldn't air in the system make the pedal soft instead of my problem of being hard as hell.
Old Feb 24, 2008 | 04:35 AM
85TrailRunner's Avatar
Air in the brake system will make the brake pedal feel spongy.
Old Feb 27, 2008 | 11:15 AM
klr toy's Avatar
Ok, here's the thing, this is all about mechanical advantage. If you increase the size of the piston in the mc, then in actuality you are decreasing the amount of force acting on the fluid. As a result it takes more force acting on the pedal to get the same amount of braking, not less. The v6 mc's use a different brake booster to compensate for this difference. They use dual diaphragms which gives twice as much vacuum as the single ones. You need to upgrade the booster to the v6 style and then you will be ok. The parts you have should be just fine. Just change out your booster.
Old Feb 27, 2008 | 03:45 PM
slacker's Avatar
just what I was going to say ... exactly !
swap the booster .
It's funny .. these companies sell you this stuff but dont tell you what you gotta do to make it work . HUH ! nice.
