transfer shifter problem
Old Jan 30, 2008 | 10:07 AM
Blue84Yota's Avatar
I have an 84 truck and when I put the t-case in 4low the transmission shifter hits it when I shift into 2nd gear we have tried to turn the t-case shifter around but then its in in 4th gear while in 2wd is there another year model that comes with a shorter shifter? Has anyone had this problem before?
Old Jan 30, 2008 | 10:40 AM
4Crawler's Avatar
Try bending the t-case shifter for clearance. Bend it at the small diameter section at the bottom. No heat is needed.
Old Feb 3, 2008 | 02:53 PM
the_supernerd's Avatar
There is a chance your shift seat bushing is very worn and the extra slop in the shifter is causing it to hit. Marlin Crawler makes a shift seat bushing that is stronger than stock.
Tykiller1994
Aug 10, 2015 07:49 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
