Rear main seal
Old Dec 21, 2007 | 12:34 PM
hitmang's Avatar
Rear main seal
Mine is leaking pretty bad. Am I better off pulling the engine or dropping the tranny to replace it? Also, while I'm in there, what else should I take care of?
Old Dec 21, 2007 | 03:01 PM
rowdy235's Avatar
Dropping tranny. Better in most every situation I have came across.
It's a stick, right?- How's the clutch? If its headed downhill, I'd probably replace that while I was in there. Of course, with the clutch comes the flywheel surfacing.
Can't really think of anything if its an automatic.
Old Dec 21, 2007 | 03:08 PM
4runnerchevy's Avatar
Banned fruitloop
Do it all!
If its a manual do the clutch, plate, bearing, and the two ltttle spring clips.
If its an Auto, drain the converter ! and refill with new stuff. Also do the tranny filter and new fluid. Hell the tranny is out, do the other seals.
Old Dec 22, 2007 | 09:49 AM
86tuning's Avatar
I'd definately do the clutch and both pilot and release bearings while you're there.
When I pull the trans out of my new beater/project, I'm going to regear the xfer case while it's out. And prolly try the 4xInnovations crossmember
Put starter contacts in too.
88sasturbotoy
Jan 30, 2026 01:57 PM
jerusry
Oct 19, 2015 05:28 PM
Iceman4193
Jul 15, 2015 04:48 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
toyoda8488
Jul 5, 2015 10:18 PM
