Power Steering Conversion 1980 to 1985
Old Feb 22, 2008 | 11:38 PM
85 PICKUP's Avatar
A quick reply would be appreciated.
Does anyone know if power steering (pump, resevoir, gearbox, etc) from an 80 PU will fit my 85? I eventually want to go to high steer, but this is a cheap alternative in the mean time. I found everything for $20 and its sucks not having it, especially when the 33's are installed. Thanks
Old Feb 23, 2008 | 05:31 AM
myyota's Avatar
The power steering pump should bolt on, but not sure about the steering box. I would check the mounting holes for each box and if they are the same then it should work. Your right, power steering makes a huge difference with larger tires.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
keithporter83
Jul 24, 2015 07:37 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
jon.r
Jul 11, 2015 03:34 PM
