new found problems...
Old Feb 21, 2008 | 10:20 AM
snysideup's Avatar
Extream Loss Of Mind!!! Carb Issue
I recently bought a carb from a yota brother on here and it is exactly what was needed...however i am going to rebuild it and dont know exactly what to order as for the rebuild kit...help please.... there is a black block on the bottom of the carb what is the name of this part....
while i was removeing the old carb i accidently broke one of two wires that connect to the top of the thermostat housing...i have the manual but have no idea what the parts name is... and is it expensive to replace the wiring harness that connects these parts...or is there a good quick fix...wire broke to close to the plug base to fix.
one more tid bit ...the tranny is original and there is so much play in the stick that no matter what gear it is in i can push or pull the stick all the way from side to side.... any ideas on what is needed and were can i get it quick and cheep...
thanks again phill for the carb, and thanks to all who can give some help...
85' yota 4X4
stock 22r
Old Feb 21, 2008 | 02:33 PM
85TurboRunner's Avatar
I can't help you with the carb issues since I've only had EFI trucks but the sloppy shifter can most likely be fixed by replacing the shifter seat bushings.
You can get them here http://www.marlincrawler.com/htm/tra...rans_parts.htm or the dealership probably.
Old Feb 21, 2008 | 02:37 PM
snysideup's Avatar
i will look into it and thanks for the awnsers....
Old Feb 21, 2008 | 04:23 PM
myyota's Avatar
You can get a good carb rebuild kit from NAPA, the rebuild kit is around 60 dollars. There are cheaper kit, but you get what you pay for.
Old Mar 2, 2008 | 04:48 PM
snysideup's Avatar
Angry I Need Some Seriouse Help!!!!!!
quick back story....played in mud yota died...sat for almost a year...bought carb from fellow yota tech commrad...installed carb...noticed carb is not the same meaning the one i took off is a california carb...the other is not...no biggie...however i have no idea what to block and what not to...got a haynes tried to hunt down vacume lines...blocked off ones that are not "needed" ...attempted to start... truck is spitten and sputten backfiren wont idle and runs like hell...have to keep the throttle to the floor and it is just not worken for me... i am utterly lost...
specs....
22r
85' 4x4 all stock....
PLEASE HELP ME!!! IN COMPLETE TAIL SPIN...
IF ANYONE CAN POST A PIC OF THERES I WOULD GIVE MY LEFT BIG TOE...AND A HUG!!LOL
theking11863
Mar 19, 2016 09:36 PM
shisha1999
Aug 14, 2015 01:33 AM
bighaydn
Aug 4, 2015 07:17 PM
irritech
Jul 27, 2015 05:15 PM
msane99
Jul 17, 2015 10:13 AM
