how do you pull codes
Old Dec 13, 2007 | 02:51 PM
gears's Avatar
my truck is a 85 extended cab 2 wheel drive automatic trans body , computer ,and wireing harness
the chassis, motor, and running gears is a 90 ish 4x4 5 speed 4 runner 22re
i know my way around later domestic fuel ingection but not as familar with this set up
heres my questions
1. my check engine lite is on, can i pull codes with out a scan tool,if so how,are they flash codes,if so how many flashes equal what
2. all the wires that go to the old auto trans are disconected i would say that this by its self should trun on the cke lite but will it cause the fuel system to go in default(runs rich)
i drove it a while with no o2 sensor then got one hooked up and it seemed to lean out a bit
thank in advance
Old Dec 20, 2007 | 08:38 AM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
code pullers for 84-up are only about 35-45 dollars at kragens, i've never used them befor but im going to buy one tomarow just to have one on hand
Old Dec 22, 2007 | 09:52 AM
86tuning's Avatar
simply jumping the check connector with a bit of wire will let you read codes. No need to spend any bucks at all. In a pinch, a paperclip will do the trick.
Old Dec 22, 2007 | 09:58 AM
DeathCougar's Avatar
Did you use the wiring harness from the 90? oR from the 85? They have two completely different connectors for pulling codes.
Old Dec 22, 2007 | 10:23 AM
4Crawler's Avatar
Here is how I pull codes on my '85:
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Dec 22, 2007 | 11:07 AM
JamesD's Avatar
jump Te to Te1 with a paper clip.
James
Old Dec 30, 2007 | 05:32 PM
gears's Avatar
that link was great answered all my question thanks a bunch
raptor510
Feb 17, 2017 07:11 AM
nonstop
Jul 24, 2015 06:29 PM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
