possible vaccum leak
Old Jan 19, 2008 | 04:37 PM
smartalec_87's Avatar
i am new here but have a problem with my truck i was hoping somone could please help. i have an 85 toyota with a 22re. My problem is that after i swapped out the head i started to get a loud clicking sound so i figured it was an air leak. i traced it back to an a/c sensor mounted on the valve cover. thinking it was bad i replaced it but i still have the sound and a crappy idle. the vaccume lines are hooked up correctly and if i turn on the a/c the revs kick up and the noise goes away. so what should i do is it an elec issue please help. thanks
Old Jan 19, 2008 | 04:53 PM
rowdy235's Avatar
Adjust the valve lash
Old Jan 19, 2008 | 06:31 PM
is that the same as the lifters and why would it change when i turn the a/c on
Old Jan 19, 2008 | 07:28 PM
rowdy235's Avatar
crap.
Sorry, missed the part about the a/c.
I'd say replace all hoses pertaining to the a/c system. See a FSM for details.
Old Jan 22, 2008 | 07:22 PM
well i checked all the hoses and if i pinch the one going to the a/c plug on the top of the valve covers the noise stops. but i checked the hose and the way the hoses are routed and it is all correct.
Old Jan 22, 2008 | 07:58 PM
rowdy235's Avatar
where does the hose go? I'm thinking thats your problem that its allowing the hose to suck air when the a/c is not on.
Old Jan 23, 2008 | 11:04 PM
it goes from the a/c thing on to the side of the throttle body. it is a plastic screw with a spring on it. that probably makes nop sense so i will take a picture of it and post it tomorrow.
he's gone
7
Dec 3, 2019 07:08 AM
87toy pickup
Sep 7, 2015 06:42 PM
93toyoguy
Aug 31, 2015 08:02 AM
4runnerjunk
Aug 22, 2015 09:06 AM
Avenged
Jul 9, 2015 07:55 AM
