Frnt Diff took way more oil then specified
Old Jan 27, 2008 | 09:30 PM
Popak2's Avatar
So I changed my oil today in my front diff. I did this when I bought the truck two years ago and don't remember anything being odd about the process. By odd, I mean the amount of oil I used corresponded to the quantities specified in my haynes manual. I could be wrong on this....
The point is that the manual says that the front diff takes 2 qts. Today though it gobbled 5 oz. short of a gallon. Is this normal or is something wrong.... I don't know what could be wrong if anything but if so I could use some advise.
thanx
Old Jan 27, 2008 | 09:38 PM
apalmer1's Avatar
As long as its not leeking give that sucker all that it can handle. Its not like it actually has oil pressure, the extra oil will just provide more lubrication. I would just make sure that you have a well done extended breather line. Im not sure if having a lot of extra oil could adversely effect it when it is submerged in freezing water with a stock breather.
Old Jan 27, 2008 | 09:48 PM
DeathCougar's Avatar
No. No no no.
Assuming your sig is correct, and you have an 85, your axle seals are leaking. That means gear oil is leaking into the knuckles, and contaminating and thinning the axle grease in your birfields.
The axle should never take that much fluid. If the level wont top out where the fill hole is, you have a problem. Sounds like a knuckle rebuild is in order.
Old Jan 27, 2008 | 10:52 PM
Popak2's Avatar
yes, my right seal is leaking like crazy. that is what i was afraid of. well, time to buy parts. Thank you for the information. I appreciate it.
krimsonone
Sep 13, 2024 09:33 AM
polo451
13
Nov 20, 2016 07:49 PM
yourrealdad
Jul 29, 2015 11:08 AM
Athansinis
Jul 27, 2015 08:38 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
