replacing motor mounts....?
Old Feb 8, 2008 | 09:23 PM
deserttoy84's Avatar
Whats the easiest way to replace the motor mount? Should I bolt them to the engine then lower it down onto the frame mounts? Or should I bolt it up to the frame and lower then engine onto the studs? Im having trouble getting the 2 smaller bolts and stud to all line up. if there is a trick too it let me know. thanks in advance!!
Old Feb 8, 2008 | 09:40 PM
muddpigg's Avatar
to the block and set on to the mount, with a hoist of course so you can shift if needer. I remember doing my 22re that way with tranny and t-case attached with a couple of guys.
Old Feb 9, 2008 | 08:22 AM
4Crawler's Avatar
Leave all the bolts loose and if needed, pull or push the engine back and forth to line up the holes.
Old Feb 9, 2008 | 12:56 PM
I did it on an incline so i ended up using a rachet strap to pull it forward and line up the bolts. They look a lot easier then they are. The new mounts are so much better, cant wait to get my tranny mount, should be smooth runnin'.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
karbin
Jul 5, 2015 11:37 PM
