WHAT THE bell!
Old Dec 27, 2007 | 01:50 PM
rayl82's Avatar
Exclamation breaks cause odd idle
ok ,got one for ya. when the 3.slo engine is warm and you apply the break the idle jumps between 1 and 2 grand any ideas? i already replaced the TPS and the problem is still there.... battery is good and alternator is great so why the issue?
Old Dec 27, 2007 | 01:58 PM
-MUDSLINGER-'s Avatar
it has to do with the power brakes, that hose that runs off the the intake to the brake booster " vacume powered " I pretty sure everything with this setup will do that if you pump them. Very weird!
Old Dec 27, 2007 | 02:09 PM
doubledizzle's Avatar
idle control valve give that a lookin at....had the same problem and tryed the brake booster but wasnt the problem...so just check the booster if not that then idle control valve most likely your problem.. good luck with it
Old Dec 27, 2007 | 02:20 PM
Elton's Avatar
tryin backing the idle down
Old Dec 28, 2007 | 02:14 PM
rayl82's Avatar
Exclamation Still No
I BACKED THE IDLE DOWN AND STILL THERE JUST LOWER RPM'S
IDLE CONTROAL VALVE IS A NO TO BUT THANKS
BRAKE BOOSTER IS FINE I HADDENT CHECKED THAT BUT I HAVE NOW, THANKS, BUT THE PROBLEM PERCISTS
ANY OTHER IDEAS?
Old Dec 28, 2007 | 03:50 PM
TrikeKid's Avatar
Hitting the caps lock button? Perhaps check the vac. line to the brake booster for leaks.
hiluxinargentina
Sep 30, 2015 05:51 PM
93RedKrawler
Sep 25, 2015 04:03 AM
Aaronmarston
Sep 22, 2015 09:39 PM
CanRunner
Jul 20, 2015 01:29 PM
