Carburetor shaft bushing?
Old Mar 15, 2008 | 06:18 PM
deserttoy84's Avatar
Alright... I rebuilt my carburetor not to long ago and have pretty much the same result. When i put my foot into the secondary a little bit it keeps revving up and has a bit more power but if i completely floor it and open up the secondary all the way it just boggs down the engine. I think ive narrowed it to either throttle shaft bushings or a weak pump. Ive checked the float level and everything and its within oem spec. Im open to suggestions because I cant really even use the secondary on my carb so climbing hills sucks. I struggle climbing a small grade with no weight. I do have 33s but I shouldnt have to sit at 4k in 3rd gear just to maintain 50mph up a hill.
Old Mar 15, 2008 | 06:29 PM
rowdy235's Avatar
fuel filter?
Old Mar 15, 2008 | 06:39 PM
...brand new
Old Mar 16, 2008 | 10:34 AM
rowdy235's Avatar
well the pump may be weak but I think you're in for a rebuild of the carb
Old Mar 16, 2008 | 03:29 PM
84sr5yoty's Avatar
Have you checked both diaphragms on the vacuum advance can? Usually the inner diaphragm craps out first.
Old Mar 16, 2008 | 05:05 PM
myyota's Avatar
^^ What he said, i had that problem on my truck, but both diaphragms on my distributor were bad. just to let you know, its cheaper to replace the distrubutor than the vacuum diaphragm, i found that out the hard way.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
the_supernerd
Oct 1, 2015 09:20 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
