PDA
View Full Version : 84-85 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. 1" BL or Hole in the floor for triple shifters?
  2. Help identifying these tranys I bought.
  3. 85 22RE, does my o2 sensor need replaced?
  4. Crawl Case Transfer Case gasket question
  5. RUF need help!
  6. axle wont center in spindle
  7. Super weird timing issue
  8. weber 32/36 vent line stall fix
  9. No heat and its cold!
  10. 1984 33" km2's fit/lift/driveshaft/gearing ?
  11. High idle
  12. Distributor has a hole!
  13. Steering box dead?
  14. shift rail modifications for duals and 4.7's
  15. Inclinometer for 1st gen 4runner
  16. Is she worth the money?
  17. Wheel hub hole
  18. 85' 2 wd 4 speed to 5 speed
  19. Intermittant Starting Issue
  20. 1987 Turbo
  21. clutch burned up??
  22. Dual case build, mixing gears from two cases?
  23. rattle after new timing chain
  24. Cranks great, starts great, runs 10-20 seconds, then dies.....
  25. Help! 4runner has me stumped wont rev past 1500
  26. Replacement body panels - rust repair
  27. 84 tranny problems
  28. Almost there
  29. '84 Bogs Down Under Acceleration
  30. 22R short block replacement and top end rebuild
  31. 4WD makes awful noise
  32. Cab swap?
  33. turn the key to the on position distributor is sparky
  34. "Resealing" heater ducting/air box?
  35. Picture request: 84-88 single or xtra cab with bed from a 79-83
  36. 22R Smog test woes (CA)
  37. no longer in the 84 85 club
  38. New brak problem...
  39. brakes leak
  40. 22RE runs rough at idle when warm, runs great in park or neutral though
  41. front seal headache
  42. 85 4runner , 1"shackle lift on flat stock leaf springs questions
  43. 1985 Pickup Steering help.
  44. Would it make a diffrence
  45. Back window wont roll up
  46. 86 4runner doors rubbing on fender
  47. Front rotors install- what else should i fix/replace?
  48. Differential Dilema
  49. rear brake help
  50. would my Gen1 '85 T4R be a viable platform for the ZUK mod?
  51. RPM's don't fall as quickly as needed?
  52. Gas milleage...1986 Xtra Cab long bed?
  53. 3.4 swap 5vzfe what tranny is typically used? R151 Find
  54. 85 Runner Jerky Gas Pedal
  55. Fender trim pictures
  56. 85 Toyota - Want to add a seat to the extended cab
  57. 22RE Freak
  58. Cracked my windshield
  59. What shocks???
  60. Oil and water temp
  61. Front wiper motor problem
  62. 1985 22R won't run right when timing is right
  63. Drive shaft flange questions
  64. Harmonic balancer fell off!
  65. Clutch Question
  66. RUF Questions
  67. Wiring question.
  68. Grooves In Axle Housing
  69. RUF need help
  70. hoping to push 40's, need some advice
  71. transmission wont come out
  72. Best bolt on lift kit???
  73. ac compressor to air compressor
  74. Flamin Green '84 Toy build-up
  75. radio wires
  76. Hub trouble
  77. New Gear Install - Need Help Reading Pattern
  78. Frame rust or "rot"?
  79. egr block off?
  80. oil pressure problem
  81. Grease in diff!?
  82. Fuel Pump Help
  83. 1984 Toyota 4Runner 22R A/C Help
  84. 3rd memeber help!
  85. Exhaust advice
  86. valve lash adjustment hangup...
  87. dual tcase, best transfer case to use?
  88. 22RET to 22R a few questions.
  89. 84 toy 22r engine rebuild
  90. another blown diff...
  91. Blower motor
  92. back window wont go up....
  93. double cardan joint with lift... any particulars?
  94. 85 truck shifter buttons
  95. 85 4 runner swapping 22re to 87 22re need help
  96. Vacuum line problem or carb issue?
  97. 1985 Parts Diagrams
  98. '84 Toyota Pickup Stumbles While Offroad
  99. Maybe a tcase issue
  100. 85 growling a bit
  101. 85 truck efi fuel pump help
  102. spartin locker
  103. 22re stalling out
  104. Spark Plug/Wire Question
  105. '84 to '88 body swappage
  106. stalling problem help plz
  107. Power steering which years are the same?
  108. Intermittant wipers erratic
  109. IFS box setup ?? - 84 4runner crossover hy-steer
  110. weber carb info
  111. stuck in 4wd after diff and tranny swap
  112. this carb is ruining my life.
  113. how to tell by sight , what the 22re stock cam shaft looks like
  114. i think i need a new or rebuilt motor
  115. Rough idle
  116. 4runner canopy mod
  117. Weber owners....
  118. 22re valve adjustment question
  119. Frame swap 84 4Runner
  120. 1985 22re 4x4 head gasket/ what are good replacement shackles over the stock ones ?
  121. 22re has a miss
  122. Looking for a mechanical water temp gauge
  123. crossmember warped after tranny swap
  124. Any Ideas? Drivetrain vibration.
  125. tranny/tcase install help!
  126. '84 22R-E Odd Idle
  127. top bellhousing bolts w56
  128. Mid range cam valve adjustment
  129. has anyone installed racing seats in your 85 T4R?
  130. manual transmission r&r
  131. weber carb/fuel pressure question
  132. steering loose
  133. truck squealing
  134. Drum Brakes
  135. Anyone running these stock wheels on their 4Runner
  136. White 4Runner with black top...Anyone?
  137. advice on 1984 tranny
  138. Igniton Timing 22re-c
  139. coolant hose identification for 1985 22R, carburator
  140. 5th GEAR POPS OUT.
  141. In the middle of steering knuckle service and ran into some issues.
  142. upgraded rotor, can't find wheel studs!?
  143. Intake Manifold covered in Oily type Crud?
  144. Soft top frame
  145. 86-88 vs 89-94 steering box.
  146. A/C Idle Up
  147. Temperature Switch help?
  148. 1985 4x4 Manual Tranny Binding
  149. toyota decals?
  150. Honestly, do they ever die...
  151. brake m/c issue
  152. 93 2wd v6 auto tranny /4wd conversion?
  153. larger front brake conversion help
  154. Do i have your old yota, from delware
  155. Putting a 22RE head on a 22R tall block (early style) - Write up
  156. 84 4runner swap from original engine to a 82 22r any problems??
  157. transfercase full of "slime"
  158. 85 4Runner leaking at left front wheel
  159. trail gear rear & ruf? or front lift.
  160. Nasty squeal coming from motor, what is it?
  161. 85 4runner front brakes upgrade?
  162. 84 Bell crank
  163. 3VZE won't rev up after new head gaskets
  164. 22r piston/rod assy question
  165. obx header for a 22r?
  166. 20R in an 84 pickup?
  167. 4runner- broken rear side window
  168. '85 Hilux with Nissan Skyline Ld28
  169. Front brakes keep locking up help!!!
  170. stuck in diagnostic mode
  171. 85 4runner fuel delivery line problem
  172. Alternator does not charge on a hot day
  173. 1985 center console
  174. 85 Pickup G52 Trans Reverse Switch = Fill Plug?
  175. 85 P/U (G.I junk) 22re starving for fuel?
  176. Fuel Pressure Guage
  177. Vaccum Advance Question
  178. 85 pickup(G.I junk), 22re electrical problems HELP!
  179. odometer runs without truck moving?
  180. 1st Gen on Longbed Frame?
  181. HELP!!!!! throttle body hoses???
  182. 22RE/22R-EC. what's the difference?
  183. 85 windshield
  184. Pics from under my valve cover, and a few questions.
  185. 22re squeak/squeal after rebuild
  186. Help identifying these hard pipes/hoses in engine bay
  187. Head gasket sealant
  188. '84 4runner no start - mechanical fuel pump?
  189. fuel pump power issues
  190. Wiring harness issues
  191. blew out reverse..
  192. slight ticking noise in my 85 22re, any help?
  193. 1986 4runner body on 1985 4runner frame?
  194. 85' 22re won't start sometimes
  195. Hard starting when hot
  196. Intake water neck sensors
  197. Alternator Upgrade!!
  198. Front suspension sag
  199. 1985 22r - where do these 2 vac lines go? (pics)
  200. 1985 4Runner Cruise Control Lights
  201. Oil Leak 22RE
  202. popped some wheelies!
  203. 85 yota brake problems
  204. Starting rebuilt 22re for the first time
  205. Electrical problem, help needed fast!!!!
  206. 85 22RE with low miles using oil
  207. 85 22R hesitation/sputter while cruising
  208. Input on sparkplug color and tuning?
  209. Welding Frame reinforcement on New Bumpers
  210. front/rear bumper fab companies?
  211. Well Engine is DEAD
  212. 86 22re will not start
  213. needed: rear crossmember/ideas
  214. rebuilt 22r wants to die when pulling out clutch and at 3krpm
  215. right(but WRONG) a/c compressor bracket
  216. 22RE starts but dies immediately
  217. Slow cold start but fine once it's warmed up
  218. Bumper advice.
  219. 1qt every 100 miles
  220. 85 22RE Hard warm start....
  221. Finding #1 TDC without a timing chain
  222. Help, replaced timing cover and now water problems
  223. 22r fuse box?
  224. 85 sfa with superwinch hubs problem
  225. anyone upgrad the ignition system on 22r?
  226. PCV and air ventilation on valve cover
  227. Funky idle problem 85 22r
  228. Need some assistance picking a lift kit/setup
  229. Rebuilt 22re Hard to start??
  230. Motor swap - 22R to 22R advice
  231. Driveshaft flanges
  232. stuck in 4 low
  233. Need help with 86 4runner
  234. 22re runs great for 5 mins... Then.....
  235. Exterior Side vent clips?
  236. 22RE rebuild / timing
  237. Doors/No Doors Thats a good question
  238. 84 Wont Start
  239. front wheel studs
  240. Which carb should I look at
  241. Need some help on blinker issues
  242. Picked up some parts for the Pickup
  243. High Pinion 3rdwont fit?
  244. What does this connect to?
  245. right tire spins, left tire doesnt?
  246. While cranking the coolant gets blown from the radiator
  247. Clicking Noise when Under load
  248. Taller guys come in
  249. 84 4runner...
  250. Need the width of front end
