Finding #1 TDC without a timing chain
Old Jul 3, 2011 | 11:22 PM
jbclem's Avatar
I'm replacing the timing chain and cover on my 1984 2WD 22R engine. When I was removing the old timing chain, I messed with the crank/crank pulley, and may have turned it 360 degrees and then back. But I'm not sure so I need to know how to determine if the crankshaft is set at #1 TDC or #3 TDC, without having a timing chain in place. The cam wasn't moved, and is set at #1 TDC.
The angle of the spark plug is pretty shallow, so it's hard to put a screwdriver in the #1 hole to check for TDC. Is there a good way to go about doing this? Since I have the oil pan off, can I measure how far up the #1 rod is and compare this to how far up the #3 rod is? Any other suggestions...
jc
Old Jul 4, 2011 | 01:11 AM
Buck87's Avatar
Here is a link to a site that explains it.
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
Old Jul 4, 2011 | 05:00 AM
takeitoutgetitdirty's Avatar
You should be able to take a flash light and shine it in the spark plug hole and watch the piston as it is moving up and down. That is how I did mine. I do not trust putting something on top of the piston, something will happen thats just my luck. Set it at TDC on the up stroke.
Old Jul 4, 2011 | 06:18 AM
Thelast83inNJ's Avatar
Usually the crank keyway is 12 o'clock straight up and down to the engine centerline on most engines. "Slightly important".
Old Jul 4, 2011 | 07:00 AM
Buck87's Avatar
x2^^
If you were on TDC before you started and your cam is still in the compression position for cyl.#1 this should work. Then follow the instructions for lining up the marks on the gears with the shinny chain links. Don't force it, because I think that this is a zero tolerance motor and valves can be damaged.
Old Jul 13, 2011 | 02:09 PM
jbclem's Avatar
Looking from underneath the engine, oil pan is off, the #1 & #4 rods are up (#1 up the furthest), and #2 and #3 are down. Would this be a good way to confirm #1 is at TDC if the crank keys(and crank pulley mark) are pointing up?
Old Jul 25, 2011 | 02:26 PM
jbclem's Avatar
I've got the timing chain installed and I want to check that everything is set correctly. I've rotated the engine through two 360 revolutions, and was expecting all the marks to show up exactly as they were before I started the rotation. But they didn't. Now I'm worried that I do have something set incorrectly. Is two 360 degree rotations right, I also tried 4 rotations but also with nothing lining up. Do I need to go 8 rotations, or is something obviously wrong?
I'm rotating the engine with the spark plugs out, and it's been smooth...would I feel it if a piston was hitting a valve?
Old Jul 25, 2011 | 02:49 PM
yoterr's Avatar
yeah you would definatly feel the piston hitting the valve, and as long as ur at TDC and your cam mark is allmost 12 o clock your good,
Old Jul 25, 2011 | 11:06 PM
jbclem's Avatar
I said it was turning smooth, but I do feel what I think is compression resistance at certain points. If the piston was hitting the valve, would it stop the rotation, and make some kind of noise, or would it just be a resistance as it passed (and the valve bent???)...
Old Jul 31, 2011 | 01:34 AM
jbclem's Avatar
How can I tell if I'm at #1 TDC or #4TDC?
Old Jul 31, 2011 | 05:13 AM
xxxtreme22r's Avatar
#1 valve rockers will be loose. assuming the head is on and the cam is "close" If the head and timing chain is not on, it doesn't matter.
jennygirl
Nov 17, 2015 11:24 AM
fasterspider
Oct 6, 2015 10:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
83flatt
Jul 2, 2015 10:30 AM
Badger62811
Jun 26, 2015 09:26 PM
